Primare A30.2 power amp has suddenly stopped working. Was playing OK, then after about half hour of non use (still powered up) it clicked and the green light went off. Both fuses (mains plug and in the unit) are fine, I've left it to cool down, tried the power switch several times with the "remote link" switch in both positions. NOthing I do will make it switch on again.
Check for the fuses inside the machine, replace only with same ratings! Make sure there's no shortcircuit at the speaker output terminals. Have it checked out by your local dealer if you are in doubt.
Pat.
Posted on Nov 30, 2008
Amp goes to half power? Even after tube replacement.
How do you know it is going half power? did you measure this, or do you only hear half the power? because then also a speaker (or more) could be not working.
Jun 10, 2014 | Mesa Boogie Mesa EXpress 5:50 2x12 Guitar...
Power lights not amp
Output problem, transistors shot
Nov 10, 2013 | Harman Kardon Harman HK 990 Amplifier
Reason for burning smell and no audio in my Samson d415
Did it suddenly stop working?
Maybe overload of amp or power supply.
I think you killed you power amp...
Feb 03, 2013 | Samson Auro D415 Active PA Cabinet - 400...
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 | B&K CT600
Primare A30.2 power amp has stopped working. Mains fuses are ok. Green light remains flashing - & amplifier inactive - even after normal warm up period (approx 10 seconds) when it would normally show a...
Hi...
It sounds like you have an output amp failure and it looks like you paid good money for it.
If it's under warranty, find a service place. If not let me know your location and I can suggest someone to fix it
Apr 02, 2010 | Audio Players & Recorders
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
It suddenly stops and the monitor is dark every half hour sometimes. What should be done ? Thanks. Michel.
control panel, display scrren saver, power options, turn display off Never Apply then hit ok
Oct 22, 2009 | Computers & Internet
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Z10 USB connection does not work
My symptoms were that the speakers stopped working all of a sudden. Display showed power but gave no access to volume adjustment and did not play sounds.
I read a vague comment by another poster and it worked!
They said to unplug it from the power plug and leave it overnight before replugging it in...... at first I dismissed this, and tried everything else to no resolution. I was ready to return the speakers but decided to unplug it and see... Bingo********! in the morning
Z-10 is now back in action.
Oct 26, 2007 | Logitech Z-10 Computer Speakers
298 people viewed this question
 Grubhead
Grubhead
