Question about NComputing Nstation Ultra Thin Client Network Terminal
Thin client not working
The thin client all of the sudden just started recognizing the power cable - the LAN and READ ports dont light up. When we change cables it doesnt work either, whereas the same cable works for others. The problem therefore seems to be the thin client. I dont know what else to try since Ive changed all cables, etc. PLEASE HELP ;)
daniel.glazier@gmail.com
2 Suggested Answers
  • 86 Answers
SOURCE: I have ncomputing L300 thin
Since you posted this four months ago, there has been some major updates from NComputing to improve the USB architecture. This should improve support for peripherals such as your printer. Download the latest software for either W2K3 (v4.9.5) or W2K8r2 (v6.1.3) and update your system. Lastly, it is critical, and I mean absolutely critical, that you update the firmware on the L300 as well. The firmware is included with the vSpace update so once the host is updated, go to the L300 and tell it to update the firmware. The current firmware version that works with v6.1.3 or v4.9.5 is v1.4.1. As of this writing, 8/16/11, those are the current versions.
Posted on Aug 17, 2011
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
When I hook it up the router port does not light up.
please check the POE after cable with lan tester if its working perfectly now its problem in radio
Jul 05, 2010 | EnGenius 80211G OUTDOOR HIGH POWER 600MW...
Have 604 router. all of a sudden only two computers can be active through the router and it does not allow the other two to work. things were working fine with all computers getting browser access... now...
On the computers that are not getting Internet access, check the LAN cables to the router. Does the Link LEDs on the router for these computers are ON?
If the LED lights are off then the LAN cable and/or network cards are faulty.
Check Device Manager on these computers to see if the LAN card is working and enabled. If not re-install the LAN drivers. If the driver installation cannot detect the LAN card then most likely the LAN card is faulty and needs replacing.
Get back to me with the results of these tests and I can advise what to do next.
Nov 16, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
How do you connect ethernet so you have both your desktop and thin client connected?
Purchase a ethernet hub. I have 1 by Linksys. They are relatively inexpensive. Plug your cable modem into the uplink jack and your desktop and anything else to the other ethernet ports.
Char S.
May 20, 2009 | Compaq Evo Thin Client T30 (311335-001) PC...
Ethernet port not recognized
try re-install all drivers and start with the chipset driver.
May 09, 2009 | E-Machines eMachines Desktop PC
Hi,could some one walk me through setting up my Billion modem wirelessly to my Dell Desk top running XP home. I get confused with firewalls,LAN settings etc Ethernet cable is being used at the moment. Do...
I am not familliar with that brand, so I do not know if it is a cable/dsl modem, a router, or a combination of the 2. I will assume it is the cable or dsl modem since you said modem.
The thing we need to do first is give you a basic understanding of whats what, and how it works.
Imagine a 3 tier water fountain. Water flows from the top, to the center, to the bottom.
Your home network is the same way. Signal flows from the MODEM to the ROUTER to the COMPUTER CLIENTS in that order. Keep this in mind. Also, remember you never, NEVER setup a router from a wireless computer client. you ALWAYS use an ethernet connected client in port 1 2 3 or 4.
Quick education about Firewalls: They are programs and devices that are designed SPECIFICALLY to BLOCK TRAFFIC. Think of them like Toll Roads. YOU have to open each virtual port for inbound, outbound, or both. Since that is such a painstaking thing, most firewalls come with default port settings, blocking the most typically unused traffic ports and monitoring the common ones, such as port 80 (the internet port) port 110 (the sending mail POP port) and port 25 (the receiving mail SMTP port). That is why typically, people who can get online (but cant send or receive email) have to disable their firewall or antivirus (security) suite, because the program is closing the ports making them useless. IF you have a router, theres a 99.9% chance that YOU WILL NOT need a firewall. Routers are firewalls by nature.
Quick education about LAN (LAN means Local Area Network, meaning a router inside your house or inside your office or a series of switches and ports setup in your apartment, your "local area") settings: Most lans are DHCP, which means nothing to you, but, in lamens terms it means that you hook it up, turn it on, and it auto configures itself. In the olden days, you had to tell your computer its address, and tell the router its address and the address of each computer, and so forth. Thanks to dhcp, they can now negotiate a lease and assign that info automatically. SO, make sure DHCP is ENABLED. and make sure your lan settings are set to "Obtain ip address and dns server automatically".
Quick education about drivers. you DO need drivers for the wireless devices, you DO need drivers for the ethernet devices, but you DO NOT need drivers for the router, and YOU DO NOT need drivers for the modem. DO NOT HOOK THE MODEM TO THE COMPUTER THRU USB! USB is never to be used unless you do not have ethernet capability, it's like a spare tire. Remove any USB wires from the modem and put them away please! The ONLY wires you want in the modem are POWER and ETHERNET. (they dont make USB routers because USB is not a networking device, USB is a peripheral device)
You will be using Ethernet connection. An ethernet connection requires that you only have the ethernet drivers. So:
YES you need to make sure your ethernet drivers are installed and that your ethernet ports are enabled and working, and:
YES you need to make sure that your wireless card is enabled and functioning, and radio is switched to ON.
Now, remember the fountain? We are going to build it here. The trick is that we have to reset the DHCP list. (if we dont, then it wont work because DHCP will be stubborn and try to talk to the other items, not knowing they were removed). So, we will need to unplug power to the modem and router and shut down each pc client... after you print these directions of course.
While everything is off, hook the main computer into PORT 1 on the router. Make sure that PORTS 2 3 and 4 are empty. (fyi, you can use those for xbox, ps2/3 or wii, or any extra computers). Now, look for a port that says "LAN" or "ETHERNET" or UPLINK on the router. (it will be an ethernet port that doesnt have a number). hook that to the cable/dsl modem. You should now have the modem, hooked to the router, the router hooked to the main pc. Lets start the water flow.
plug power into the modem and wait 1 minute for DHCP synch with the company. (usually you see a sync light or a ready light).
once the modem is synched with the ISp, plug power to the router and wait 1 minute. (so the router can get the dhcp from the modem)
If your modem and router are combined in 1 device, then just wait for synch with isp.
Now start the main computer and try the internet. If you can get online, you have a good network connection. The rest will have to be done by the wireless router mfr, but it isnt hard. In fact, by default, you should be able to start your wireless and get online through it now, but you may want to consider wireless security, (WEP WPA) settings. Call the rtr mfr for those. (its not hard, just tedious and this post is long enough already).. lol. Quick note about wifi: its flaky. If you have a 2.4 ghz phone in your area you may drop connection (wireless only). try different wifi channels to resolve the issue, (call router mfr).
Mar 11, 2009 | Dell Computers & Internet
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Neoware Red light power
Power Supply is Shot...I've been working on literally 30 of them for my company....I'm not happy. If you know of any company who will be willing to sell them. Please tell me. HP wants $50 to Fix Just the Power Supply Board
Jun 08, 2007 | WYSE Wall/VESA Bracket Kit, for Select...
NComputing Nstation Ultra Thin Client Network Terminal Logo
60 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
