Can't access the printer - Computers & Internet
  • mrbrown0603
    mrbrown0603 May 11, 2010
    Is the Printer connected directly to your computer with a USB cable or are you trying to access it in a network?
    What is the operating system of your computer and model of printer?
    Master:
  • 538 Answers
Unplug the printer from the computer..leave computer running..turn off printer..plug printer back into the computer...then turn printer on..see if operating system sees the printer..if not..new printer drivers will be needed..go to printer website, and get them by model number and operating system
Posted on Oct 09, 2008
It print all color blue
use the printer utilities
Using the Printer Utilities
how to
Accessing the printer software You can access the printer software from most Windows applications, or from the Windows Start menu.
When you access the printer software from a Windows application, the settings that you make apply only to the application you are using.
When you access the printer software from the Start menu, the settings that you make apply to all of your Windows applications.
Refer to the appropriate section below.
From Windows applications
Follow the steps below to access the printer software.
Click Print or Print Setup on the File menu. In the dialog box that appears, click Printer, Setup, Options, or Properties. (Depending on your application, you may need to click a combination of these buttons.) The printer software opens.
From the Start menu
For Windows Me, 2000, NT 4.0, 98 and 95 users, click Start, point to Settings, then click Printers.
For Windows XP users, click Start, then click Control Panel, then click Printers and other hardware, then click Printers and Faxes.
For Windows Me, 98, and 95 users, select your printer, then click Properties on the File menu.
For Windows XP and 2000 users, select your printer, then click Printing Preferences on the File menu.
For Windows NT 4.0 users, select your printer, then click Document Defaults on the File menu.
May 13, 2015 | Epson L210 - multifunction printer /...
Error code 3806
From Kodak support:
Open the printer access door.
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer.
Turn the printer on if necessary.
After the printer has powered up, the message "Printer access door open" will appear.
Close the printer access door.
Remove and install the printhead two times.
Wait until the printer is ready to use.
Jun 07, 2012 | Kodak   ESP5250 Es Printer
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Mar 18, 2011 | Kodak Office Equipment & Supplies
Error # 3802
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
If the error continues:
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Nov 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error 3806
You can try the following workaround:
- After the printer has powered up, the message "Printer access door open" will appear.
To install a print head, please checkout the link below:
http://selfservice.kodak.com/service/main.jsp?t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=1771
If the above solutions fails. You may need to consider going to a local service center for further assistance(possible hardware failure).
Oct 28, 2010 | Kodak Office Equipment & Supplies
Printer error : 6203 comes up.
Follow these steps:
  1. Open printer access door
  2. Turn off power,wait for 30-40 seconds,then turn on power
  3. Now turn on printer and it will show 'access door open'
  4. Close printer access door.
I hope this error 6203 will not occur then!
Cheers!!!
Oct 19, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Printer shows error code 3802 printer will not print
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
What is error code 3802?
"Printhead failure" - #3802 Solution (from Kodak website):
Feb 16, 2010 | Kodak ESP 5 Printer
Printer printek web password
you can access this networked printer by their IP address
just connect through printer's IP address and you will get your printer access...
Mar 27, 2008 | Office Equipment & Supplies
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
