Mackie TH-15A Active DJ Powered THUMP Speaker Stand and Cable Set TH-15ASET1 Logo
gerald smith Posted on Jan 07, 2012
Th-15 power light comes on and goes off but there is no sound
rafaelt49
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 10, 2022
rafaelt49
Contributor
Level 1:
Answers
Questions
Helped
768
Points
Power switch short circuited, change wires to unused terminals of the switch, problem resolved
Jose Miguel Carcamo Cruces
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 13, 2013
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2913
Points
6
Short circuit in secundary of the power supply or power amps damaged.
2helpful
2answers
No sound coming out of my mackie
Whether you are experienced in electronics repair?
if not, try this simply way:
1: Test whether the power amplifier is still working. See figure 1.
Power OFF,adjust the EQ settings as shown in the picture.
Minimize LEVEL.Switch ON Power. Touch pin 3 at the INPUT socket by using a small screwdriver or piece of wire / cable.
Slowly raise the LEVEL,a little bit only (as the clock showed 7-8) until
sound is heard in speaker. If not heard, slowly raise again LEVEL.
If audio input signal is heard,it can simply be taken to mean
that the amplifier is working.
If LEVEL at 9 o'clock position,and the audio is not heard,
the possibility of the amplifier is damaged.
Switch OFF the power. Take it to a repair place.
2: When the Power LED is lit, but no sound,
There are many possible causes, one of which is:
I have been getting 3 times similar cases, and all are caused by
two Rectifier-Diode (either or both.) damage on the power-supply-unit.
Remove/desolder,measure, if damaged replace it with a new one.
See figure 2-3.
Hope it helps. Regards.
2answers
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
No sound out of my mack th-15a
As Tom Jones sang 'It's not unusual....' The amp has probably gone and you need to get it fixed. These are not the most reliable and I would suggest getting something better from another manufacturer if you can afford it, perhaps a local shop would do you a trade in if they can fix it?
How do i connect thump 15 A powered speaker to powered mixer?
You failed to give us the most important information... what brand and model of the mixer? Youwill use balanced interconnect lines to a balanced MAIN output jack, assuming it exists...
Hi, I need to know how do you replace the 1" compression driver in a mackie thump th-15 and where would i get one from ? cheers.
After removing the back cover disconnect the tweeter cable form the terminal. Then hold the tweeter magnet and turn it anti clock wise. The driver unit will unscrew and come of the horn assembly.
Keep the driver unit on a firm table and unscrew the four + screws. It has a sandwich assembly which will part into two if you put a sharp knife and twist. You will see the tweeter diaphragm which can be lifted up again by using a sharp knife. The replacement diaphragm is available from the below given address
http://reconekits.com/tapcothumpth-15ahorndiaphragmpn0013252-1.aspx
2helpful
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
3answers
Bought a used Mackie TH-15A. When powered up there is no sound...at all.
The internal amp is in need of repair. Are there any other symptoms or signs?
The active light does not light up when I plug my guitar in and no sound comes out from the talkbox ... But the guitar sound can run through it to an amp where the guitar sound comes out
It sounds like you have NOT connected the power adapter to the box to power it. The guitar sound won't be too loud as you run the hose to your mouth and pick up the sound with a microphone such as a Shure SM57 which then goes to your amplifier. Without the power adapter the internal amplifier will not produce any output.
2answers
TH-15A won't make sound. Comes on, then flashing front light
This probably means there is a failure and the internal protection circuits have activated. It will probably have to go to a shop for repair.
1helpful
Behringer XENYX 2442FX Mixer. The power light does not come on, The +48V does come on. The solo light blinks Constancy. No sound. I checked the fuses, they seem to be OK. any ideas on what wrong
You have likely lost one, probably the +15 volt power supply... This is possibly a shorted component or a short on the circuit board causing this. It takes some skills at troubleshooting to find this. Sometimes using a thermal imaging camera will show hot spot... other times you have to search with a millivoltmeter. The rude solo light is driven by an op amp that uses both polarities of 15 volts and to turn it on it pulls negative... Hence I suspect the +15 is missing.
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
