Question about Konica Office Equipment & Supplies
I have a konica 7040 and I need to know how to set it up on the network where do I put the IP?
  • Konica Master
  • 6,680 Answers
4 Suggested Answers
SOURCE: setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
Posted on May 03, 2008
checkitright
  • 1362 Answers
SOURCE: Konica 7040, use as network printer?
Not sure if you are saying it has a NIC card or you would like to put one in.
If it does not have one, yes it's expensive and most likely they did not make one for that model.
If it has one
depends on the connections.
IP address is for a network, don't know the setting you are in,but, if there is another connection ( Parallel) this is the big connector that is used in the old machines and computers (before USB) and is connected directly to the PC. so it's considered Local printer and only that person can print, would be an alternative.
Unless you have a wireless router, and put the printer into a shared File
Posted on Sep 30, 2008
  • 6 Answers
SOURCE: konica 7040 error code F-34-3
Friend, this code refers to short-circuit the corona separation and transfer, check for accumulation of toner and do a cleanup in the corona.
Posted on Jun 01, 2010
Konica Minolta C252 network ip address refuses to save........
check the network setting and we will go from there,
utility(Hard key)- 3)Administrator settings- (passwords is : 12345678) 5)network settings 1)TCP/IP settings
You might need to reset the login and password to be able to print to that printer, especially if the previous SysAdmin had set up the BizHub to require a login and password to print.
Sep 25, 2017 | Konica Minolta Office Equipment & Supplies
How to change ip address to konica minolta dialta 470 or connect to printer from computer
work out ip address of computer like for example usually 10.0.0.2 or 198.168.0.2 submask 255.255.255.0 then go to printer and select settings - network settings - ip address and put in xx.xx.xx.253
xx.xx.xx is the network address like 10.0.0 or 198.168.0 and the same subnet mask as computer is using. .
computer run
dos prompt
type in
ipconfig
press enter key
Jan 23, 2017 | Konica Minolta Office Equipment & Supplies
How to install konika minolta with computer
To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
Feb 18, 2015 | Konica Minolta BizHub C252
I have a Konica Minolta BizHub C351 need to know how I can set up the ip address in order to be able to print to it. And any advice you can give me on the drivers using Microsoft Windows 7
Go to Konica Minolta web site US I assume down load driver for your machine. GO to Admin Settings PW 00000000 or 12345678 default. Network settings common setting to get IP address info
Dec 19, 2014 | Konica Minolta bizhub Office Equipment &...
I can't get my konica minolta c300 to print through my network nor through a direct connection to any PC since I installed windows 7. Also, I do not remember how to pull up the IP address for the...
First of all bring your machine on network.All you have to do is to just connect the network cable to it.Now press these buttons,Utility/Counter,Check details or details,Now select Administrator,enter admin password which is 12345678.Press enter.Now press NETWORK SETTINGS,In this option go to IPv4 setting. In this option enter IP address manually and put it on manual setting.Now press Details settings, then press Ping confirmation.Enter the IP which you want to ping and press Start button.This is how you can ping any ip address frm machine and bring your machine on network.
May 23, 2011 | Konica Minolta Bizhub C300 All-In-One...
I have a konica bizhub c351, I have changed my network here at the office. This IP address is 192.168.15.50 and now I need to change it to 192.168.0.50. Can you help me?
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Nov 25, 2009 | Konica Minolta bizhub C351 All-In-One...
Need written instructions on how to reset IP code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
May 05, 2009 | Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Oct 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
If it has one
Sep 30, 2008 | Office Equipment & Supplies
56 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
