Question about IBM ThinkPad T43 Notebook
Hinge broken My left hand hinge has broken. Anyone know how to remove it? (Then i will be a part on E bay and replace) Thanks.
    Guru:
  • 257 Answers
I hope to do this you will extra-ordinary careful in handling or removing the components process
1. You will have to loosen the screw at the back of the system and then raise the keyboard up gently then you will see a transparent cabling nylon at the back of the keyboard remove it from the motherboard gently and put that aside after that you remove the bracelet and the palmrest so then you will find tiny screw holding the hinges to the screen then gently loosen the screw and bring the hinges out then follow the removing skill to replace them back
2. If you need any assistance then post it again.
please rate this solution.
Posted on Oct 08, 2008
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
The right and left - hand hinges of my Asus notebook got damaged. Where can I have them repaired? Only those parts got broken a little bit, just like semi-fructures. Thanks.
Hi, Just go to ur nearest computer shop and ask them to replace that hinge! the hinge becoming stuck and only solution would be to replace it! The crack can be repaired and repainted if there is no available parts in the market. Ur concern should be the hinges, replace it before it breaks the whole hinge holder!
Jun 14, 2011 | ASUS Computers & Internet
RIGHT REAR HINGE ON CARTRIDGE BAY SEEMS TO HAVE POPPED OUT, RENDERING THE PRINTER UNABLE TO PRINT (LID WILL NOT CLOSE ALL THE WAY ON RIGHT SIDE).
find the switch where the door presses to tell the printer its closed.
find something to press that when you want to print then remove it when you have to swap cartridges
May 05, 2011 | Computers & Internet
Where do i put windscreen washer in my renault clio 8v 1.2, 2002
open the bonnet and its beside the right-hand bonnet hinge under the wiper. its not actually in the engine bay but in behind the firewall. if the car is left-hand drive it might be beside the left-hand hinge. if you cant find it ill put up a picture for ya
Sep 20, 2010 | 2000 Renault 181
The left hand hinge cover has broken..can I get a replacement?
You will have to return the laptop to where you bought it and tell them what you want done. They will send it off to the manufactuer and replace the broken hinge, but you may be charged a small fee.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | Samsung N13013B Netbook
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Maytag Skybox Broken Door Hinge
go to www.apdepot.com enter your model number and a parts breakdown will come up you can order parts and they will ship to you
Sep 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Teba Mini Kitchen (Oven & 2 x Hotplates). Left hand side hinge on oven door has come undone? Doesn't look broken, looks as if metal clasp inside has come off?
i can fix most anything. i have one of these and would love to get another. how is it today? email me at rnb3875@hotmail.com. thank you , robin
Jun 29, 2008 | Kitchen Ranges
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
How do I replace the LCD screen hinge on my IBM T41?
I'm sure you could get these hinges from IBM, but no idea as to their cost. They are available on e-bay for $8-$35 (depending on whether you want 1 or a set) plus $8-$10 shipping.
As far as replacement. You will have to remove the Top cover assembly from the base of the PC. If you need help with that, just let me know and I'll talk you through that.
To replace the hinge, you will have to disassemble the Top cover assembly.The screws that you will need to remove are covered by small black adhesive covers. There are 3 round ones along the bottom of the bezel, 2 square ones up at the top of the bezel (to the left of the white LED keyboard light, and 6 (trapezoidal shaped) on the outside of the cover (3 on each side). Carefully remove those covers and the screws that are under the covers. Keep track of where the screws should go back in.
The actual bezel is held into the top cover with some internal snaps. Start at one of the corners, run a knife blade along the seam (between the cover and bezel) and you will hear each fastener "snap" as you slide the blade past it. Once the bezel is loose, lift it off of the LDC screen. There is one additional screw that is located up in the upper right hand corner. That one will need to be removed, also.
Gently lift the right hand side of the LCD assembly a couple of inches and place something of appropriate size to hold it in the raised position. You will see 2 additional screws that hold the hinge to the LCD assemble. Remove those and the old hinge will come right off.
Position the new hinge and replace the two screws that you had just removed. Reverse the removal sequence to reassemble the display.
Before you start snapping the bezel back into place, check to make sure that the two cover catches (those hook things, up at the top of the LCD assembly) are both operational. The link going to the left hand one tends to easily fall off.
This procedure should take in the neighborhood of 45 minutes to an hour.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Nov 15, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T43 Notebook Logo
277 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
