Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
Sony cbyershot When I plug my camera into the usb port on my computer, the computer does not recongize my camera at all. However, I just tried it on my laptop and it works.
  • 10,594 Answers
This means Cybershot is OK. Some thing to be checked in computer.
Try it in another USB port of computer. Check USB drivers of PC and better to update it by going to support page of your computer brand.
Posted on Oct 08, 2008
My cam can not be recognized by my laptop... its the first time this happens... i can not transfer my pics to my laptop
Try camera in another USB port of laptop and also check it with another USB cable, if still problem not solved then plug camera in any other computer to make sure that it is problem of camera.
If camera still wont work in other computer then its USB port got defective, please use memory card reader to transfer pictures in computer, take out memory card from camera, put it in memory card reader and plug it in USB port of computer.
Thanks.
Feb 28, 2011 | Sony Cybershot DSCW310 Digital Camera
Sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
May 08, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My computer wont recongize my mp3 palayer when I plug it in to the port. I think my usb port is broken on my Mp3, is it fixable?
Try this before : go to my computer icon on desktop----mouse right click----proberties----devices.
there you should be able to solve the problem .
rate if useful please !
Jan 17, 2010 | Audio Players & Recorders
My computer do recongize my mp3 player
Try connecting the device to a different USB port, preferably at the back of the computer, if it is a desktop. Otherwise, try updating the USB drivers, if you know how to go about doing that. Restarting the computer with the device plugged in also MIGHT fix the problem. Good luck ;)
Jan 07, 2010 | GPX Audio Players & Recorders
Plug USB cord into computer to transfer photos..on camera screen it says mass storage and the USB is not recognized
Plug camera in any other USB port of computer as some time one particular USB port stop to recognize it.
Oct 20, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
When I plug my sandisk into the computer, I can't find it-but if I plug memory stick into same plug I can find it. How come my computer is not recongizing the sandisk
i was having the same issue, the usb port i was using was in the front of my pc, it wasn't recognizing it.. i plugged it into one of the usb ports in the back of the pc and now it seems to be working fine... hope this helps
Jul 25, 2009 | SanDisk Sansa e260 MP3 Player
Computer does not acknowledge the camera when connected via usb
in that case try to use other usb cable, the n plug it directly to the usb port of your motherboard at the back of your cpu casing, try to use all the port, if they did not work, now you can use now a card reader, put your memory card to the card reader then plug it on the mothernoard usb port
Jun 30, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
My camera stopped uploading photos
If the camera still works OK otherwise -- you caN BYPASS THE PROBLEM with coimputer recognition simply by removing the SD card, and reading it directly. Most notebooks have a slot for plugging in an SD card. Otherwise -- there are some very cheap SD card readers (<$5.00) -- insert your card, plug into USB Port, then (on Windows) select "Open Windows Explorer" select and copy your digital images to your PC.
Feb 26, 2009 | Pentax Optio 60 Digital Camera
Usb ports not recongized
Do use in the front ports, sometime this port is unplug to the motherboard so it need to connect before you can use that port. In the back port you can always use that ports in there it is safe to connect any plug and play device such as flash disk or usb port printer. if this both not recognize your any device you inserted then probably your device is dead. try insert your device to other pc to see if still working if not then maybe the driver of your pc are not installed. try reinstall all the driver of your system.
may this help.
melnavz
Feb 19, 2009 | Gateway 830GM PC Desktop
Camera won't let me upload!
try useing it on another computer you dont have to install sony software to use the camera on another computer if it dose work that tells you that its prob your USB port.
Feb 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
