HP officejet copy machine. 7210 keeps beeping and flashing message (very quickly) "Close door" Doesn't appear any doors are open. Copier works but keeps making beeping sound!
    Scholar:
  • 62 Answers
Could be one of two things. Either there is a door or cover you are overlooking (very easy to do), or there is a switch actuator that either needs adjusting, or replacing. Try opening every cover and door you can find, and taking out the photoconductor unit, unplug it, and give it a good looking over (front, back, inside). Put photoconductor/toner unit back in, and close all covers FIRMLY. This is where I would start if it were me. Hope some of this helps!!!
chad
Posted on Oct 08, 2008
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Cartridge door open message won't go away
see door switch your door switch have problem
May 27, 2012 | HP Office Equipment & Supplies
HP 7210 All in One keeps showing a paper jam, but there isn't one. What should I do?
Turn off the Printer
Remove the Rear Access door of printer
Check if the Rollers have any dust/ bits of paper
Clean the rollers with lint free cloth ( upwards just like the paper is picked and rolled )
Close the rear access door
open the front access door
Move the Carriage ( while holds the cartridges ) manually 5-6 times from left to right side
Check if there are any paper pieces stuck
Close the front access door
Turn on the printer - It should work fine
In case it gives same issue -
Disconnect the power cord from back of printer ( while printer is on )
While holding the # and 6 key, Connect the cord back
Release the # and 6 button after 3-5 times
Follow the instructions on the screen to align the cartridge
NOTE : doing the # 6 reset will erase Fax logs, Speed dial # you have saved in the printer.
Jul 06, 2010 | HP 7210 OfficeJet All-In-One Printer
HP Officejet 7210 All-In-One Inkjet. Arrived at
In absence of another solution, I finally switched the Officejet off. No idea if that "trashed" the memory or anything else, but it's working again - for now.
I am surprised that nobody, especially HP, has a real answer (let alone a solution) for this problem, when the same question about the same model has been asked since 2007 or before! I'll keep hoping, because the consensus seems to be that the "Assert! Memeory trashed?" WILL happen again.
Dec 02, 2009 | HP Officejet 7210 All-In-One InkJet...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Paper Jam in a HP 7210
there is a door at the back of the printer , open the door and remove the paper
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
56 people viewed this question
jasbo
jasbo
