Question about Fujitsu fi-4120C Path-Through Scanner
Fi-4120c2 error Code
Im working on a customers scanner that is a fujitsu fi-2140c2. its giving me an error code of E3. if any know what that error code is, that would be great if you could pass that information along to me.
thanks
    Novelist:
  • 104 Answers
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Posted on Jul 27, 2010
How to fix FUJITSU fi 5900C e18 error code Fujitsu fi-5900C Pass-Through Scanner
you need the detail code to e18 to determine the exact error.
First generate the error code again , then hold down the document thickness keys together.
The display should change to a two digit numeric .
You need this code.
Jun 15, 2015 | Fujitsu fi-5900C Pass-Through Scanner
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
Error 2148285
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Apr 21, 2014 | Fujitsu Fi-4120c2
I need the software to fujitsu fi-4120c2 - I have windows 7
Hi kimberly...
fujitsu fi-4120C2 printer drivers can be found at driverupdate us (xp/vista/7/8).
It will take 2 mins from you to install...
after updating, go to word and try to print something
I hope I have helped you...
enjoy
Apr 06, 2012 | Fujitsu ScanPartner fi-4120C2 Path-Through...
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Please go throgh my answers posted posted 6 days ago. Hope the Hope the information provided in that post will be helpful.
Please revert if you have any doubt.
Regards,
TechSatya
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
I got windows 7 home premium 64-bit os and fi-4120C2 scanner is not recognised because no 64-bit driver available. What is the solution?
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/windows7_bulletin.pdf looks like a waiting game for drivers. They say by the end of January they might have drivers. Just keep checking windows update and the Fujitsu site.
Jan 23, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu fi-4120C2 scanner
There are two generally components for a scanner to work, One the Hardware Driver, which connects to the Comp and Two, a program to scan using the hardware connected. Sometimes, both may be available in the same program. For example, after installing the Device Driver, you can use any scanning program, to scan. Hence please check if you have loaded the Device Driver. You may be just using the scanning software, whcih is not able to detect the device!
S. Mohan, Chennai, India
Jan 20, 2009 | Fujitsu ScanPartner fi-4120C2 Path-Through...
E3 error on fujitsu fi-5530C
You have a rear optical error.
check the lamp is lighting.... open the ADF and push in the cover open switch. if one if off, replace it or the lamp inverter
swap the cameras over to be sure the fault follows to an E2
replace the optical unit
good luck
Jan 09, 2009 | Fujitsu fi-5530C Scanner
Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Dec 05, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu fi-4120C Path-Through Scanner Logo
3,870 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
