Question about Toshiba 57HX81 57" Rear Projection Television
Horzontal feathering Md l 57HX81 SN. 59009581 CHASSIS 0159 I have severe horizontal feathering at start-up. Especially bad with an non-HD signal. After 15 min warm-up usually pretty good for an hour. Then the picture flashes intermittently. I am using a signal from a HD DVR. Thanks for any help. I am an industrial electronic tech with Ball Corp. I can do board level component replacement. Especially if you tell me what is real heat sensitive. David
  • Toshiba Master
  • 19,396 Answers
Check this service bulletin and test the components described, it may be the same problem.
Posted on Oct 08, 2008
Modul la32r71ba
It's the signal you are feeding it. If you are using non-HD, and especially non-digital signal to a HD TV it will be very noisey and grainy.
May 20, 2014 | Samsung Televison & Video
Fix. Tv
This line is due to fault to horizontal sweep section. Replace all the non-electrolytic capacitors with new ones. Replace the horzontal output transistor too. Check this linkhttp://electronicshelponline.blogspot.com/ to get more details.
May 13, 2013 | Televison & Video
Horizontal black bands on copy
i would recommend you call a service technition on this problem.... it could be several things, the corona wires need replaced, the fixing assembly might need to be rebuilt, and or the drum might need cleaned and or replaced
May 21, 2010 | Canon NP 6050 Copier
Re: KDL-40S2000 black horizontal lines
If you have a horzontal black line (left to right) panel is bad.
Sep 04, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen not coming on
This Chassis line had a lot of issues with hair-line cracks in the Horizontal Circuit along the right side near the High Voltage Transformer and Heat Sink. It has also had issues with cold solder connections in the Horizontal Drive Circuit especially the Horizontal Driver Transformer. These issues have many times caused a massive Power Supply and Horizontal failures if not repaired.
I hope this helps,
Skyassoc
Jul 24, 2009 | Sony KV-32S22 32" TV
Toshiba 57HX81: Green works but Blue and Red seem to be out.
Do you still have reds? Is the image still clear though discolored? If so you ought to replace the blue bulb which has most likely failed. The part no for the 57HX81 model blue CRT bulb is TOSHIBA     23008753.
Jun 11, 2009 | Toshiba 57HX81 57" Rear Projection...
57HX81 Toshiba. picture gets squiggly on dvd input
Perhaps 2 things. Does TV get a picture without DVD connected? If so I would bet you have a faulty connection in your signal board where the in jacks are at the back of the TV . Check to make sure cable from DVD are not bad, I have used cables before and got a false positive. Try turning and spinning the jacks once you have a picture.Make sure your signal board is firmly pressed into its slot on the signal board chassis. Thats it for now. Good luck.
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
HD4208TIII-PDP 42'' Plasma TV
Your TV may not support your HD channel signal. Check with HD DVD & non-HD DVD players to confirm.
Jan 01, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
HORIZONTAL HOLD
Hello INDIII,
The answer is yes, if all you have to do is to adjust the horizontal hold control (usually located on the back of the TV)
The answer is no (with caveat) if you have to open up the set. This problem occurs when the horizontal oscillator is drifting off its set frequency of 15,750 Hz This can be caused by a component or components changing in value, or the problem could be caused by the loss of or decrease in the amplitude of the horizontal sync pluses within the video signal. Such a loss of amplitude can take place from the output of the Video detector to the Horizontal mixer stage (uses the Video pluses and the Horizontal oscillator to sync the picture). This means that you will be working around a hazardous section of your TV.
The caveat is if you have a background in electronics and you have the proper equipment.
1) schematic diagram of the TV to see where TV test-points are
2) multimeter to measure DC voltages at test points
3) oscilloscope to view waveform patterns in the horzontal section of the TV
4) Signal generator to produce a know good signal into the TV set.
5) Isolation Transformer to connect the TV power plug to to isolate the Tv ground from earth ground and allow proper connectivity for test equipment (plug the unit under test into the isolation transformer and the test equipment into the wall outlet.)
I hope this answers your question,
Thank you,
Shuttle83
Nov 26, 2007 | Televison & Video
My screen has horizontal lines across it
its the ram
mine does the same took ram out replace
Nov 24, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Toshiba 57HX81 57" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
