Question about Copystar CS-2050 All-In-One Printer
Randomly prints symbols
Our printer is connected to a networking system and only one computer is having a problem. The one computer can print some things normally but some things is just prints out in symbols. Anyone know how to fix this?
  • Copystar Master
  • 2,794 Answers
Try replacing the network cable that the computer is connected to with a different one.  If all the other computers are printing fine to it, usually that is the culprit.
Posted on Oct 08, 2008
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
I moved my HP 4000 printer from one office to another. When I hooked It back up, it printed out a few pages of symbols and then will not print at all. The ready light is on, but it will not print. Any
If you get a bunch of meaningless symbols on the page the usual causes are a corrupt or wrong print driver, a bad communication cable or a failed formatter or possibly a print job stuck in a queue on the computer that you connected the printer to (pending jobs often corrupt when you reconnect your printer). Unplug the parallel or network cable from the printer and restart and then try to print the configuration page. If it prints then plug in the communication cable and try printing again. Still bad after that reinstall the printer driver. If a fresh driver does not work, try a different cable.
Sep 17, 2014 | HP LaserJet 4000 Printer
Printer printing crazy symbols
just delete all print from printer and restart printer and computer then try again
happen because some cancellation of print during priting
Mar 31, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
Page misfeed
There are 3 solenoids that can cause this. Two of them are easy to get to and the third is in the back behind the circuit board. Here is a link that will show you how to fix it. There is one under the fan.
https://www.youtube.com/watch?v=4n7cIiyrk_Y
Oct 07, 2012 | Konica Minolta magicolor 2400 Laser...
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
Can I connect my printer to the uverse router USB port for sharin
If your using Windows operating system you can share your printer. That way you can keep your printer on one pc and when the other pc wants to print it will connect to your printer over your home network and print.
How to setup it in Windows XP
To share the printer, I opened the Printers and Faxes folder on the computer that was connected to my printer.
To open the Printers and Faxes folder
• Click Start and then click Control Panel.
• Click Printers and Other Hardware, and then click Printers and Faxes.
• In the Printers and Faxes folder, I clicked the printer's icon and, in the tasks pane, I clicked Share This Printer.
• I opened the printer's Properties dialog box, and clicked on the Sharing tab.
• I clicked Share Name, and then clicked OK.
That's it—the printer was immediately available for other computers to use.
Now that I had a network printer, I was ready to connect to it and print from other computers on the network.
To connect to the printer
• I opened Control Panel, and clicked Printers and Other Hardware.
• I clicked Add a Printer.
• Instead of adding a local printer, though, I clicked Printer Connection and then browsed the network for the printer.
The whole process took less than a minute before I was printing to the network printer as though it was connected to the computer.
Nov 30, 2009 | Computers & Internet
My 8050 is printing symbols and jargon instead of text. Help
ok disconnect ur printer frm ur computer and turn it OFF for 5 min,after 5 min turn ON it again n dont connect it to the computer.it will not print those symbols
now on ur computer check that is there any pending printing or last time u used da computer to print and its left on pending.ckeck it on where the clocks is shown on taskbar.if yes so cancel all the pending printing and then connect ur printer back to computer.then u shall not face the problem.
Nov 29, 2009 | HP Photosmart 8050 InkJet Printer
Printer LCD says Cartridge Problem - Tri-Color. Refer to device documentation to troubleshoot.
Before you can troubleshoot the problem, you need to determine its cause.
To determine the cause of the printing problem:
1. Print another PDF file, such as the first page of Acrobat Help:
-- If that file prints correctly, the PDF file that doesn't print correctly may be damaged. See "Resolve problems printing a specific PDF file from an Acrobat product" in this document.
-- If the file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a .txt file) from another application (such as Microsoft Word or WordPad):
-- If that file prints correctly, the problem isn't system-wide--it's specific to the Acrobat product. However, the way Acrobat interacts with the system may affect printing performance. Go to step 3 to eliminate some system-related causes of the problem.
-- If the file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDF files. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF file:
-- If the file prints correctly, your system may have been out of memory or resources.
-- If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory, and then turn it back on and print a PDF file:
-- If the file prints correctly, the printer's memory was too full.
-- If the file doesn't print correctly, go to step 5.
5. Print from another computer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the printer or the network correctly. Contact your network administrator or consult your network documentation.
-- If the file doesn't print correctly, go to step 6.
6. Print a PDF file to another printer:
-- If the file prints correctly, the computer you first tried to print from may be unable to connect to the original printer because of a communication, hardware, or memory problem. Make sure that the printer is turned on and connected properly, and then run a self-test on it to make sure that it's working correctly. For instructions, see the documentation that came with the printer. You may want to contact your network administrator for assistance.
-- If the file doesn't print correctly, see "Resolve problems printing any file from any application" in this document.
you can try these option and then try to resolve them and you can find the solution on follwing link==http://kb2.adobe.com/cps/316/316508.html
For more free tehnjical support you can visit-----http://tinyurl.com/lkrpwy
Jul 06, 2009 | HP Officejet J4680 InkJet Printer
Connecting a network printer to 2wire 2701HGV-w
This is a little tricky technically it your printer isn't made to go onto the network, but you and do one of to things... let me start with the most cost effective way and that is
1. Hook your Printer up to a computer that is already on the network and then go into windows and SHARE that printer giving access to all the computers to print to it that you need to. I don't know what Operating System you have so your going to have to give more information to get clarification on exactly what you need to do in the Operating System to share the printer. The CONS of this approach is that you can only print to that printer when that computer is on. So if you want to have continuous ability to print to that printer you will have to keep your computer on.
2. You can get what they call a Print Server... and connect it to your printer and your network.. turning your printer into a network printer. Of course you might need to get more detail depending on what Print Server you choose. The Cons of this approach is that ofcourse your going to have to buy more equipment... but the pro's are you won't have to keep other computers on in the network to print to it. One last note you will find Print Servers in the store where you find Routers and Hubs.
The best of luck to you... and I hope this Helps... after you decide which way you want to go you might want to contact me or one of the other techs to get more percise approaches to installing your equipment... but we will need to know you Operating System, and the Print Server... if you go that route. Good Luck! I hope this works for you!!!
Sincerely,
cdixon18
The Man Inside the Machine
May 20, 2009 | 2wire (1000-000057-000) Modem
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
Copystar CS-2050 All-In-One Printer Logo
109 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
