Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
Blue shadow I Have a Sony KDF-70xBR950 and im getting blue shadowing on all video sources i replaced the lamp, tried to adjust color still nothing helps. Just out of Sony's extended warranty,(optical block) even after I contacted them thru their Sony support & service, before warranty was dropped. Positivly will not help me. Origionaly, they had me do some fix me's that I knew would not fix problem. At this time they should have told me of extended warranty offered for this problem. I think It's Sony's responibilty to contact people who purchased affected TVs of any extended warranty's, but they would probably go out of business, because they would go broke.
  • 535 Answers
U have to connect orhorised service center its very hard to repair it so u need to go with
Posted on Nov 05, 2008
    Brigadier General:
  • 3,614 Answers
A variety of issues can influence poor picture quality, including settings on the TV, electrical devices in close proximity to the TV, and connection issues with the signal source. Follow the steps below to troubleshoot issues related to poor picture quality.
IMPORTANT:
NOTE: If model-specific information is required to complete any of the steps below, refer to the operating instructions supplied with the TV. Manuals are available online in the Manuals/Specs/Warranty section of the Sony Support Web site.
  1. Make sure there is no glare or reflection from an external light source on the TV screen.
  2. Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference. NOTE: Vacuum cleaners, fluorescent and halogen lights, and some battery-operated devices (including toys) have been known to create RF interference.
  3. If your TV has a Digital Noise Reduction (DNR) function, turn this feature on.
  4. If your TV has a Digital Reality Creation (DRC) feature, try turning it off or on.
  5. If your TV has a Sharpness or Picture Mode setting, try adjusting these options. NOTE: If the television menu is fuzzy or blurry, then service may be required.
  6. If you have a projection TV, try adjusting the convergence of the picture tubes.
  7. Try plugging the power cord into a different electrical outlet and/or surge protector. NOTE: These symptoms can occur if the wall outlet is improperly wired or not producing the proper voltage. If using a surge protector or extension cord, it also could be faulty.
  8. If the issue is still not resolved, select the appropriate device below to troubleshoot the signal source and connections.
  • 10,594 Answers
there are two possibilities either Blue LCD ( I'm talking about color engine) itself is defective or it has enough amount of dust layer.
Now they way is to open color engine and perform cleaning. If problem resolved, pretty good. (You need to do LCD alignment after cleaning)
If not, Blue LCD need to be replaced ( might be complete color engine)
Need further info, let me know please.
Good Luck.
Posted on Oct 08, 2008
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 08, 2008
    Above solution is applicable if you have expertise in TV repair and good electronics knowledge.
    Shahid Electronics Oct 10, 2008
    hope you received solution email.
    Shahid Electronics Nov 05, 2008
    I was expecting your comments but nothing from your side.
    Extended warranty is better option to resolve TV issue.
    Sergeant:
    Champion:
  • 200 Answers
HI
You have a bad light engine or in Sony TV sets, it is called an Optic Unit Block Assembly. This is a very expensive part and should not be attempted to be replaced by a novice. Call an authorized Sony repair place to have this repaired. Good Luck
Thank you
  • Thafa Oct 08, 2008
    Hi
    see this link for repair the tv
    http://www.repairfaq.org/sam/tvfaq.htm
    thank you
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Jan 27, 2015 | Sony Replacement lamp for Grand WEGA or...
Black and white picture and no color
The video controller adjustment section for color has defaulted to black and white because the circuit board may have been affected by a power surge or power outage. It may be that the Video board needs replacing.
Feb 26, 2014 | Sony Grand WEGA KDF-70XBR950 70" Rear...
My sreeen is green yellow help
If some areas of the screen or all of it in the kdf-70xbr950 are off color in this fashion it is likely a bad Optical Light engine which Sony is replacing even if the set is out of warranty for free.
Mar 19, 2012 | Sony Grand WEGA KDF-70XBR950 70" Rear...
A blue shadow on the left side of the picture. Do
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The blue line appeared at the lower border of the letterbox
easy fix. adjust the vertical position of the image using the on-screen menu.
Mar 06, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony Grand WEGA KDF-70XBR950 70 in
You need a new projection lamp.......(XL-2100 replacement DLP lamp)..... go to this web site to get the lamp you need for your TV model KDF-70XBR950 70inch----
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040980
------ This web site shows you how to install it yourself. ----
http://guides.fixyourdlp.com/sony/XL-2100U.php    --------- I strongly suggest that you get a SONY manufactured replacement lamp NOT a cheaper lamp from another manufacturer... it costs about $200.
Adelaide B.
Oct 30, 2008 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Blue shadow
Sep 14, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
259 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
