I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is connected to the Verizon wireless router/modem. The problem I am having is this, my linksys wireless router is still transmitting and the new Verizon router is also transmitting. I can connect to both but only the Verizon wireless router seem to be working. The linksys wireless router, even though I can connect to its network, is not working, that is I can't go on the internet with it.
  • aojiku01 Oct 08, 2008
    Thanks. I will try this when I get home.
  • 2,794 Answers
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router. should work.
Posted on Oct 08, 2008
How can I make settings to support DHCP IP assignments and also recognize my manual IP's assigned to the LAN connected devices?
The easiest way I can think of is to shrink the DHCP address pool.
To do that, at least on the model of Actiontec router I have, click on "Network (Home/Office)" the go to the "IP Address Distribution" section of the screen. "DHCP Server" should already be selected, and under that, you'll find "Start IP addresses" and "End IP addresses." Usually, the start will be and the end will be What I usually do is change the start address to That leaves over 50 addresses for normal wireless connections, and I'll general assign IP addresses from the rest of the range as follows: to routers, APs, etc. to printers to for other static devices. (I often find that Blu-Ray players, cable boxes, etc. behave better if they have a static address.)
But really, on home network, I doubt you'll have more than 15 devices that need static addresses, so you could set the DHCP start address as low as if you wanted to.
Sep 17, 2015 | Linksys Computers & Internet
Am using verizon fios wireless router 9100em but would like to add my linksys wrt54g for all wireless functions. Both routers use to access router menus I can access the verizon but can't get...
You will need to change the dafault ip of one of the device.
Connect using a calbe lan first browse the ip
then change one of the device
Then set one as (ap repeater) access point router..
ok try this
Jun 30, 2010 | Linksys Wireless-G WRT54GS Router...
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
I cannot connect with linksys wireless router
From your description, you appear to be connected to the router fine.
Try powering down the modem from Comcast for about 2 minutes then power it back up. If it doesn't come back, call Comcast service as it is likely on their end.
Hope this helps.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Dropping wireless connection
The problem may not be with your router. I had a situation a year ago with the modem dropping the signal everyday. I spent hours on the phone with verizon tech support to no avail. They sent someone out to my home and he put a filter on the main line coming into the house which didn't resolve the issue. Then verizon insisted the modem was bad so they sent me an actiontec. Turns out that the problem had nothing to do with me. They try to squeeze as much bandwith at their switching stations as they can. They switched me over to another hub and viola no more problem.
May 20, 2008 | Actiontec GT704WG Wireless Router...
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : , the subnet mask should be
Open the setup page of the Access point, by typing in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Mar 28, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
231 people viewed this question
David Payne
David Payne
