Question about GE Refrigerators
Model css25uswcss refrig. leaving for winter- loacated in mountains - house gets below freezing.need to drain the water tank.I see how to remove shelves etc. How do you access and drain
  • 5 more comments
  • perce7319 Oct 08, 2008
    Where is the solenoid. Is there some way to disconnect the unit I don't have a compressor.
    Where is this solenoid? What do I need to remove to disconnect the unit and drain. I don't have a compressor. On old machine used to remove a drain.
    There is nothing wrong- I just need to drain the tank before leaving for the winter. Side by side- GE model css25uswc.
    Where qre the connections inside the frig. I can take out the shelves and see the unit.
    Please if you are not familiar with the model by pass and let somebody give me specific directions Thanks
    Thanks- thats how it works when it is hooked up. I need to drain the tan
    I need to disconect the unit and drain- I don't have a compressor. The old frig I could see where the connections were. What do I have to remove to get at this unit. It needs to be drained otherwise it will freeze over the winter. I guess it is the same procedure as if I was replacing this unit. Again GE model 'css25uswc ss' a side by side refrigerator.
    You are not reading my problem. I HAVE to drain the water reservoir because it will FREEZE when we turn the heat off. This happened a few years ago to the older frig.
    Everthing is fine with the power on and the house heated. When the house temp gets well below freezing it does not matter if the power is on or not the reeserve water freezes.
    The water left in the tank will freeze- How do I manually drain it?? I drain all the water pipes.
  • perce7319 Oct 09, 2008
    Finally found someone who read the question. Will try tomorrow.
  • 749 Answers
On this model you will have to cyphon out the water with a small tube or hose once you remove the waterlines.
Posted on Oct 08, 2008
  • 943 Answers
HI the tank is behind the crisper's. remove the crisper's, remove the tank covering disconnect the hoses top and bottom . pull tank out store till next year have a good winter . thanks the appliance doc please rate my answer. thanks
    Scholar:
  • 116 Answers
For the picture of drain hole click this link
http://www.applianceaid.com/images/sxsdrain-hole.JPG
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies.
click this link for the picture of defrost drainer how to keep it safe
http://www.applianceaid.com/defrost_drain_freezes.html
My fridge is freezing things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
A tip from Gerard in Georgia: My Sears ( Frigidare built ) refrigerator suddenly started freezing thing in the refrigerator compartment. I started to replace the cold control, not having found any other problem, when I discovered that the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly. Luckily, I found this before rushing out to purchase the control
On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture one, example picture two, example picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
  • 1,543 Answers
Letting the water freeze in the water reservoir tank should not harm the tank, but to be extra safe:
  • Remove the bottom grill on the refrig.
  • Disconnect the water line at the fitting near the hinge. Newer models have insta-push fittings. For those fittings you have to push the collar in toward the center of the fitting as you tug on the tube. Some insta-push fittings use a colored collar (red or blue) to prevent this from happening accidentally. just remove the colored ring first, then proceed.
  • Remove plastic water lines at the back water valve the same way.
  • You can then blow into line to force water out the other end if it does not flow by itself.
  • Carl Schulzetenberg
    Carl Schulzetenberg Oct 09, 2008
    Hope I caught you before you leave the refrig for winter.
    I forgot to mention that freezing water in the water valve can crack the valve.
    take all tubes off (inlet and two outlets) and if possible put 120 volts across the two coils on the valve for a few seconds to get a bit of water out of the valve. Depressing the water dispense (with power to the refrig.) will probably be enough.
    Also, it if this model has a internal water filter, I'd remove that too to prevent cracking of it from freezing.
    Thanks for the FixYa rating. Have a nice worry free winter. Carl.
    President:
  • 2,712 Answers
There is nothing to drain. the fridge does this automatically when its turned on. I dont think there is any part that you can manually remove (without removing the bottom of the fridge).
    Sergeant:
    Champion:
  • 334 Answers
Refrigerator
Refrigerators have a drain in their floor. Water from melting frost flows out this drain, into a pan and evaporates. Food particles can clog the drain and cause odors. Clean the drain regularly by removing its stopper and using a pipe cleaner or similar device to push any accumulations through to the drain pan below. Force a cleaning solution of detergent and water through the drain. Empty, wash and replace the pan. You should also vacuum the condenser coils along the back or bottom of the refrigerator.
  • nick helpap
    nick helpap Oct 08, 2008
    do u see any resvoiur plug also
    New Friend:
  • 51 Answers
The refrigerator drains It's self. Drain water from a refrigerator flows to an evaporating plate located adjacent a compressor, so that heat from the compressor promotes the evaporation. A water spreader spreads the drain water as it reaches the evaporating plate to facilitate evaporation. Water which is not evaporated on the evaporating member gravitates to a container and is reabsorbed by the other evaporator member when the latter dries. The evaporator plate has ribs to efficiently use the heat received from the compressor.
    Genius:
  • 3,422 Answers
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Can you let me know if this is a freezer on top ro bottom or side by side model so that i can give you a diagram for your model.
  • 958 Answers
Remove the hose after the solenoid for the water supply.
blow unto the hose to discard the water from the tank to the hose of the dispenser.
if your blow is not strong enough, use air compressor.
tnx 4 using fixya,
drcool
  • francis rivero Oct 08, 2008
    the solenoid is located at the back of the fridge. it has two solenoids, one for the water dispenser and one for the ice maker. remove the one for the water dispenser and blow on that one to remove the water at the tank.
    tnx again,
    drcool
    sorry for the delay in response, we have different time zone, the solenoid i am talking about is where your water goes in the fridge. the water line from your house gos first to this solenoid, then divides between the water dispenser and ice maker. they are then connected to each hoses to the water reservoir and ice maker (if u have ).
    now remove the hose that goes to the reservoir then blow on it to purge all the water in the tank. the water will come out at the dispenser.
    i hope that would help you solve your problem
    drcool
No manual for Keystone Cougar 2013 330RBK ~ not sure how to winterize.
There should be plugs underneath the camper to drain the water tanks. Remove them and let the water drain. There should also be a plug on the water heater, remove and let water drain. There is also a bypass valve on the water heater to divert water away from the heater, turn this to bypass. After the water has drained replace the plugs except the water heater plug. The heater plug can stay out. Fill fresh water tank with RV antifreeze, usually about 3 gallons or maybe a little more for larger RVs. Run pump opening faucets one by one till water is forced out and the antifreeze flows including toilet. When antifreeze is flowing out the faucets close faucets and shut off pump. When pump is shut off open faucets, the antifreeze may get slushy in very cold conditions but wont freeze and a little may drip out of the faucets. The water heater may still have a small amount of water in it but shouldn't be a problem if you leave the plug out. Make sure the blackwater and greywater tanks are empty, you can dump a little antifreeze down the drains and toilet to make sure the sink traps are free from water and the blackwater tank has antifreeze in it. Other than that just shut the propane tanks off and youre done. Try to leave a couple of windows cracked slightly to promote airflow and reduce condensation inside the camper
Nov 13, 2016 | RVs
How do i winterize my pool
Remove all drain plugs, open any valve you can and have. split apart any union, and depending on the part of the country you live in, the permafrost is a factor. If you freeze below ground, then you will also need to empty your pool down below the lowest inlet fitting and then blow the water out of the lines.
Once clear of excess water, plug the holes so rain water does not refill them!
  • heater will have 2-4 drain/winter plugs
    • also remove the pressure switch
  • pump will normally have 2 plugs
    • Open & remove lid from hair & lint pot
  • Pool sweep booster pump has 1 plug
Any low spots in the plumbing will trap water in them. Drill & tap a hole - 1/4" Normal pipe thread - that is the most common size of a winterizing drain plug. Others may just cut the pipe right at the lowest spot and glue in a union for future winterizing.
Mar 02, 2015 | Pool & Spa
Need to know steps to winterize a 2001 Thor-Citation 23-R trailer. Or schematics of key points to address.
If you don't have a hot water heater winterizing bypass kit installed,get one before going any further.
Next, drain the water out of the hot water tank. Add POTABLE (not automotive) anti freeze to the water system Run run faucets one at a time both hot and cold, toilet and shower head until you see the anti freeze . Next, shut off the water pump and open the faucets. This saves any chance of cracked water lines. When you want to use the trailer again, close the bypass valves on the hot eater tank and run the pump long enough to remove the antifreeze solution from the system. Fill the water tank and run the faucets for a few minutes. Potable antifreeze won't make you sick so there's no worry if you don't get it all out of the system.
Nov 02, 2014 | RVs
Winterize vcross 365 fifth wheel
I think you have posted this several times so I wanted to add this.
The best thing is to have a dealer do it. You need to know if you have by-pass kits installed, depending on what you have for storage tanks they need to be drained, RV non-toxic anti-freeze needs to be added to plumbing and flushed through, water lines should be blown out along with draining so if there is a place where the water was level it gets forced out.
Here is a quick info for a skyline, but it really depends on what you have for plumbing.
Purchase 4-6 gallons of RV approved, non-toxic anti-freeze.
2. Drain all tanks, fresh water and sewage tanks.
3. Turn water heater by-pass valves to by-pass position. (The by pass valves are located near the
water heater incoming lines - an access panel may have to be removed depending upon the
model.)
4. Drain water heater.
5. If installed, remove water filter from assembly and discard. Install diverter if included.
6. Pour an amount of RV non-toxic anti-freeze into the fresh water tank to fill the tank above
minimum water pump operating level. (Use of a long funnel may be helpful) Add more, if
necessary, during procedure.
7. Turn on pump switch and open the cold water side of all faucet fixtures. Leave open until the
anti-freeze comes out (generally, pink in color). Repeat for hot water side.
8. Flush toilet until anti-freeze begins to flow into the bowl and then pour one gallon of anti-freeze
down the toilet to winterize the black tank.
9. Pour anti-freeze down each shower/tub, lavatory sink, and kitchen sink to fill p-traps.
10. To winterize gray tank(s) pour one gallon down each related sink drain.
*****Now the best thing is to post a new post and see if someone has your manual to be exact.
But if you get no response, and refuse to let a dealer do it, you have a little bit of info to help you.
Sorry I couldn't find the exact method for your model.
Apr 09, 2013 | Sport & Outdoor - Others
Winter closing instructions
Winterizing your Spa or extended period shutdown If you don't have plans to use your spa during the winter months, you should drain it completely well before the temperatures get low enough to produce a hard freeze.
Hot tubs that are heavily used by bathers should be drained every 3 - 4 months. When it's time to drain, either drain to a sanitary sewer or use the water for lawn irrigation. Make sure no chemicals have been added for at least 48 hours before draining.
Water in spas filled with sprayed foam insulation will still freeze if not heated. Finding and fixing leaks in that foam is a nightmare! These recommendations could potentially save you a lot of money!
These basic steps will ensure safe, effective shutdown of your spa for the winter months or any other extended period with out use. Factors such as spa installation, location, type will affect the steps and procedures.
Use these recommendations as a guide.
  • Disconnect the spa from the power supply.
  • Open the drain valve (if installed) or pump out all water.
  • Remove the filter cartridge(s). Clean & store in a dry place. (FILTER FLOSSER)
  • If possible attach a wet/dry (shop) vacuum (capable of blowing air as well as vacuuming) to the hole in the bottom of the filter housing.
  • Using the blower function, blow out any excess water through the plumbing system - allow a good 5 minutes of blowing time.
  • Use the shop vac to remove any water blown through the jets into the tub or towel dry any remaining water from the spa, until it is completely dry.
  • Leave drain & gate valves open, if you have rodent issues we recommend MOUSE AWAY.
  • Close the spa cover and fasten with tie down safety locks.
This is not a job you want to do in freezing conditions, give yourself enough time. Make every effort to ensure ALL of the water is removed - including remnants in the pump lines and jets.
These are common sense steps always be safe around water and electricity.
Sep 20, 2012 | Pool & Spa
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
Winterizing a well pump and pressure tank
Remove the drain plugs and install drain valves so you can open the drains by hand instead of always getting tools and eventually stripping the plug heads.
Nov 28, 2009 | Plumbing
I am a builder. I installed my Bosch dishwasher.
Hello Gerry, There are two (2) ways to accomplish this. The easiest is to get some RV anti-freeze (enviromentally safe version) and put that into the bottom of the dishwasher as per the instructions. Then when you return in the Spring, just run an empty rinse cycle to purge the dishwasher of the anti-freeze solution.
The other method will require you to remove (pull out from under the cabinet) the dishwasher and (with power turned off!) disconnect the sump pump boot to drain the residual water out of the unit. In some models, there is a small drain plug that you can remove to drain the water out of the bottom sump (pump) section of the dishwasher.
Good that you thought of this, as many folks forget that leaving water in their appliances in freezing conditions can cause some major headaches from burst pipes, pumps, etc. if they aren't properly winterized for the freezing temperatures they'll get in an unheated building.
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Bosch Dishwashers
What do I have to do to winterize my pressure washer? It will be in an unheated shed all winter.
Gasoline goes bad after sitting for an extended period of time.
Old school people would drain the gas out of the tank but found this lead to rust forming in the tank.
Now it is best to fill the tank with high octane gas and use a winterizing fuel additive to prevent problems.
Also remove any water from the hoses.
In the spring replace the gas and change the oil and you should be good, changing the spark plug would also be beneficial.
Oct 10, 2009 | Northstar Pressure Washer 2800 PSI
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
