Question about Acer Aspire 5100 Notebook
Compaq Presario F572 Notebook PC
Turns on and works fine for awhile but then starts to flicker and then goes blank. I have to shut down the computer to get it back. Happens intermittently; does not seem to have a pattern of time, happening whether working on or off the Internet
  • jcheung_99 Oct 18, 2008
    Same problem on my Acer Aspire 5100. Can go dark at any time. It may come back on if I close the lid and put it on standby mode and then make it wake up. Or turn the machine off and on again. Is it the LCD inverter need to be replace. The LCD itself is still in perfect shape if it is not dark. I mean the brightness and color is perfect when it is working.
  • 33 Answers
Just see any virus is afecting your sytem ..or else try reinstaling windows solves ..it ..
Posted on Nov 05, 2008
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
I have a compaq presario CQ50-215NR notebook PC, and after a couple of hours of watching videos, the screen goes blank, and nothing can function, although the power is still on. What is causing this?
The most likely culprit is heat. When a laptop overheats, it shuts down to protect itself.
Buy an inexpensive cooling pad at Stuff-Mart or a computer store or simply slide a paperback book under the back edge so that air can circulate under the machine.
May 01, 2010 | Compaq Presario Notebook
Compaq Presario V6000 rebooting blank screen
I am almost sure that it is a motherboard. When all of the lights stay solid and it seems to start, but shuts off is most likely the motherboard. You can save the data if you get a proper enclosure for the hard drive. You can call Compaq support to make sure that those signs are the motherboard.
Jun 30, 2009 | IBM ThinkPad T40 2373 Notebook
I have a compaq presario x1000 that wont let me get past the logo. It was working fine one day, but then I shut it down. The next morning I booted it up it the computer never went past the Compaq logo.
It is likely that the hard drive is bad or a memory issue. I would start by removing the hard drive and see if it goes past the compaq screen. If it does then you know what is wrong. If not message me and will walk you through the next step
Jun 30, 2009 | Compaq Presario X1000 Notebook
Compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
May 29, 2009 | Compaq Presario CQ50-215NR Notebook
Problems starting up
This fault is caused with hibernation settings.
Turn it off in control panel, power options.
Problem will be gone then.
All computers struggle to come out of Hibernation.
Regards
Richard
Apr 22, 2009 | Compaq Presario F572US Notebook PC
COMPAQ CQ60-104Tu goes blank... improper shutdown
It might be a problem with the computer. I would advise going back to where you bought it and returning it to either get a new one or a different one. Glad I Helped!
Jan 28, 2009 | Compaq Presario Notebook
Compaq presario 700 no picture
u just try for the buttons in the down of ur pc or may be at the sides..............just press it an enter the menu for adjustments...........there will be an option called DEGUASS just press it once.......ur pc's screen will shake for a while and then stops.........then u will get an clear display.or press F8 and change the settings.
Sep 08, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
