Question about HP Scanjet 4370
Won't scan pictures/documents, etc.
Hi! Our HP scanner will make copies - but not scan to HP Pavillion a1350n. I can scan pictures w/scanner using PhotoShop software - just not directly from scanner.
Thanks for your help!
  • HP Master
  • 5,568 Answers
This is a strange one- and the following may not help;
- Open the Control Panel, then Scanners and Cameras - Delete the listing (if present) for the HP
Leave the scanner 'on' and reboot the PC.
If the weather is right, Windows may (should) find a 'new device' and reinstall the driver for the scanner. If that fails to cure the problem, either reinstall the HP scanner software or download updated software from the HP website (good luck with that - it's a nightmare getting what you need).
Posted on Oct 08, 2008
Straight thin line prints on copies from feeder
When the paper is fed through Automatic Document Feeder (ADF) it is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying! For example see the below picture: -
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Hope it helps! Good Luck! Thanks for using Fixya!
Oct 18, 2011 | HP OfficeJet J4580 All-In-One InkJet...
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
How do I copy documents?
Unfortunately you won't be able to copy directly from this machine since it's only a printer. If you have access to a scanner you can use it to scan your document, save it to your machine, and then print it on this device. Otherwise you'll need to purchase a Multi-Function machine that includes a Scan/Copy feature.
May 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
Hi all, I have a F380 All in one from HP connected to a HP Pavillion w5540 with Windows XP SP3, and everything is working properly. However, when I hit the "scan button" it opens the utility software...
Do not hit the SCAN button. Instead, use the HP software, and click the "Align" button.
Follow the on-screen instructions (print the page, put the page into the scanner) very carefully.
Oct 22, 2010 | HP DeskJet F380 All-In-One Printer
I can't scan a photo or document
If you want to scan open Microsoft Word and go to Insert -> Picture -> From scanner or camera.
You can do the same with Paint. Go to File->From scanner or camera.
Then you will select your scanner and scan your document or photo.
Feb 10, 2010 | HP DeskJet F380 All-In-One Printer
How do i use my scanner
If you have loaded the software for the printer/scanner.
Go to your HP director Icon and start this program.
you should see your Scanner / printer listed under Select device.
You can place a document/picture in the document feeder on top.
OR you can place the document / picture directly on the glass.
(Lift the hinged lid to reveal the scanner glass)
Don't worry the document feeder uses a different scan wand.
Now document / picture in place select the Scan document or Scan picture icon from the HP director. Depending on which type of document you have placed in / on the scanner.
Scanner should warm up then scan presenting you with a preview image. From here you can decide what and where to go.
You are not limited to just the HP director.
Other applications can use the twain source to activate your scanner software. This will transfer the scan to your application.
Irfanview is a prime example. Image viewer that will let you "Acquire" and image from you scanner. Be sure to select the twain source.
Nov 10, 2009 | HP OfficeJet J4580 All-In-One Laser...
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
First time scanning
To send copy of printed documents to others, follow the steps below.
1. use your scanner to scan your printed documents, save it to jpg format.
2. Use your email to send the pictures.
login to your email
compose or create the message
attached the images
Hope that helps.
Jan 06, 2009 | HP Scanjet 4400c Flatbed Scanner
Please help me figure out why my Hp PCS 1410v won't scan
Jul 02, 2008 | HP PSC 1410v All-in-One Printer
HP Scanjet 4370 Logo
142 people viewed this question
Ben Johnson
