I have a Dark "Tint" strip down the left side of the picture screen. Does anyone know what exactly is causing this? I believe it is the DMD board but what part exactly and can it be fixed without having to replace the whole board?
SOURCE: Dark shadow
I found this forum with others who had the same problem. You should check it out:
http://www.avsforum.com/avs-vb/showthread.php?t=758625&highlight=samsung+shadow
SOURCE: HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
