Question about Lexmark E232 Laser Printer
First print of day fails
The first print always fails requiring a shutoff and restart of the machine, Then it is fine. This also happens if I do not use the printer for several hours.
TBS, East Rochester, NY
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Still having problem???
Posted on Oct 23, 2008
Chainsaw won't start?
2 possibles
coil is getting hot and failing
do you have spark straight after it stops
is air filter clean
carby diaphragm or carby rebuild required
May 31, 2016 | Garden
What would make a snow blower run for 15 minutes then shutoff, restart for 30 seconds and then shutoff again?
Buddy of mine had a arise brand with a tecumpsi motor it was bought new. Believe it or not, the exaust valve stem was just a little long made that way from factory. When it would warm up the valve would expand just a little and create low compression. Then the thing would be impossible to keep running. Took it apart and filed the valve stem down and it runs like a champ again. Good luck!
Feb 04, 2015 | Measuring Tools & Sensors
Pitney Bowes E700 doesn't print at all althougth the mechanism appears to be working fine. I've changed the cartridge and cleaned the print head and run maintenance several times but to no av
Addressing Original Question: Its essential that the PB E700 machine is linked to Pitney Bowes account to either a) add postage or, b) carry out an Inspection. within 90 days or machine will start flashing "Inspection Due" if this is ignored after a further 30 days the machine will start flashing "Inspection Required" and stop printing! Perhaps this is the solution required.
a) First Connect machine to telephone line as if you were going to top up with postage.
b) Press "Refill"
c) Press "0"
d) Press "Enter"
Machine should display your current balance with PB.
And the Inspection message will be cleared.
Hope that helps. I also misunderstood the "Inspection" message thinking it was referring to a maintenance requirement, when it is actually an antifraud/security requirement of the postal authorities to check location and usage of the machine.
Mar 07, 2012 | Office Equipment & Supplies
My machine keeps turning itself off and on while I am trying to sew. Help me please. Thanks a million.
You have an electrical short somewhere, check the pins that go into the machine in case one has been pushed in or broken, check the plug on the lead that goes into the machine, if there is any disolouration you will need a new harness, failing that it will be a shop test.
Sep 13, 2011 | Bernina Sewing Machines
I have a hp color laserjet 2820, it says "replace supplies" and "device busy" . It was working fine yesterday and now won't print.
The replace supplies means that something has either reached end of life or has failed and needs to be replaced. Device busy usually indicates that there is a print job queued in the printer that needs to print, but the supplies out is stopping that from happening. Clearing the print queue on your computer and then restarting your printer might clear the device busy error, but the supplies error will likely require replacement of something.
May 01, 2011 | HP LaserJet 2820 Printer
Every time I try to watch any online videos such as youtube, hulu, or even netflix, my computer restarts and its always at random time into whichever video im watching, sometimes it may not happen, but If...
Check the Windows error logs. You did not mention what OS you have (!!). Look under admininstrative tools >> Event viewer, in the control panel. This will give you clues as to what is failing.
I suggest that you immediately extract the hard drive and backup all of your data. Something big is going on and system failure is coming soon.
Feb 05, 2011 | Office Equipment & Supplies
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Print spooler stops / Printers missing from machines
try C:\WINDOWS\System32\spool\PRINTERS
this path in spooler path
Jul 14, 2009 | Ricoh Aficio MP1600SPF Copier
Not able to access programs or shutoff correctly
Have you opened the computer case and cleaned out all of the dirt and lent lately? The way you discribe it happening after a period of time leads me to think the CPU is overheating .
Dec 28, 2008 | Dell Inspiron 530 Desktop Computer
Lexmark E232 Laser Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
