Question about Panasonic Televison & Video
GOT I/O ERROR AND DRIVE WILL NOT READ DISK? - Panasonic Televison & Video
    President:
  • 2,712 Answers
The Windows error "I/O Device Error" means there is an error in the computer's ability to read data when you try to install a program or to copy data from your CD or DVD drive. This issue is likely to occur when Windows tries to use a transfer mode that your CD drive cannot use or does not recognize. To resolve this issue, you will need to change the transfer mode in your IDE channel properties.
Steps To Change IDE Properties if (!window.netshel_ord) { netshel_ord=Math.random()*10000000000000000; } if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++; window.google_render_ad();
  1. Click the Start button
  2. Right click My Computer
  3. Select Manage from the resulting menu
  4. In the Computer Management window, select Device Manager
  5. In the right pane, click to expand IDE ATA/ATAPI controllers
  6. Identify your CD/DVD drive in the expanded menu and right click the appropriate drive
  7. Select Properties
  8. In the Properties windows, click the Advanced Settings tab
  9. In the Transfer Mode box that represents your CD/DVD drive (typically Device 1); open the dropdown menu and select PIO Only
  10. Click ok and exit all windows
If this does not resolve your issue, then you will need to go back using the above procedure and change the Device 1 in step #9 back to "DMA if available". Then, change Device 0 to "PIO Only" in the Transfer Mode box.
For reference, the Device 0 is the Primary IDE Channel and the Device 1 is the secondary IDE Channel.
After you change your settings, make sure you restart your system so that the computer recognizes the changes you have made. After you reboot, check the settings to make sure they are in effect. If they are, your device should now work properly.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 08, 2008
What is a disk error
Problem with a drive. Like not being to read or write. This pertains to any type of drive.
Dec 26, 2012 | Electronics - Others
Tip
Major hard disk Read ERRORS
Many people say that they have major hard disk Read ERRORS, and sometimes loose data, That is to die for, even some attempt suicide. :)
Any how There are few steps to be followed up in order to get your peak hard disk performance
1. ALWAYS CHECK YOUR POWER SUPPLY for right power that is giving to your hard disk , cause in some countries power failure or load shedding or power cuts are even more then developed countries so in those countries power supply can damage the hard disk , but according to my own personal experience Disk Read Error are found to be in SATA drives much greater then the old IDE hard drives
2. Always give the C drive volume less then other drive (c drive is in which windows is to be installed)
like for instance you have a 80 GB hard drive and
you have 4 drives C: D: E: F:
then give
10 GB to C:
20 GB to D:
20 GB to E:
30 GB to F:
it can be done when you are installing any OS , cause in this situation you have to create partition for these drives .
in that case due to windows files in contact to 10 GB the hard disk will be optimized.
3. Always De-fragment your DRIVES from time to time especially DRIVE C:
here is an image how can you perform that
4. Perform data recovery scans & automatically fix errors
when ever you get a read error go to any file
follow steps
(i) My Computer > drive c( or whatever your drive gets read error ) >properties
(ii) in tools tab click error checking (check now) button ,
then in sub menu check for check the automatically fix file system error
and also check attempt of bad sectors
then press start ......
it will take some time cause it completes 5 phases,,, ( i recommend this when you are free and not using any drive )cause even sometimes it takes a restart .
see if it helps you ... do vote
on Apr 03, 2011 | Computers & Internet
I couldent format my computer when the computer restart the error mssage apper the massage says disk read error
1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi...
or rather than doing this try the alternative which is windows own repair
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any
bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
also download a registry cleaner
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
hope this helps
Oct 16, 2012 | E-Machines emachines (emachinees) CD-ROM...
Disk read error
hope this helps
Sep 28, 2012 | Dell Latitude E6410 Laptop Computer (Intel...
A disk read error occurred
Was this read error on the hard drive, or on a disk installed in the CD/DVD player? If it was a hard drive, then running Checkdisk on the drive will detect and isolate any failed areas. If too many failures occur, you may want to consider a new drive before total failure (and loss of data) occurs. If it was a CD/DVD read error, then the disk may e dirty or scratched. The drive may require cleaning. Or, if the disk was burned on a PC and not commercially, the media may not be fully compatible with the drive in your machine. Some media don't work well with some brands of drives. Almost all manufacturers websites list recommended media for their drives.
Jan 12, 2012 | Gateway DX441X Intel Desktop PC - Intel...
When copying it says i/o device error :(
An "input/output" error is an indication that either:
* some data from some part of the W.D. disk cannot be read 100% correctly;
* the data has been correctly read, but the error occurred while writing the data to your 'C:' disk-drive.
Either way, you have a disk-drive that is "dying", and should be replaced, as soon as possible, before _NONE_ of the data on the disk-drive can be accessed.
Check the warranty-status of the disk-drive -- the manufacturer may replace it, at minimal cost to you.
Dec 03, 2010 | Western Digital 320GB MyBook External USB...
I have a dell inspiron 1318. whenever i turn the laptop on, there is a black screen with a "read disk error has occured" message...it keeps bringing me back to the same screen...what should i do?
Disk read error is indicative of a hard disk drive failure. If under warranty, call Dell for a replacement drive. If not you can buy drives at places like Newegg.com or EBay
Sep 20, 2010 | Dell Inspiron 1318 Notebook
I have a IMB think pad T22 and when I start it up it always says a disk read error occured
Might want to check your boot sequence. I suspect it's reading either CD drive (or floppy drive) prior to your Hard disk drive. Make sure to empty contents in that drive prior to boot up so as to avoid the errors (harmless errors though)
Aug 17, 2010 | Computers & Internet
This is the error message that I receive when I turn on my Dell Inspiron 9100: A disk read error occurred, press Ctrl + Alt + Del to restart. When I follow those directions, I continue to get the same...
hi there, a disk read error doesn't sound like a CD drive to me. It sounds like a hard drive failure to me. My advice is to take out the hard disk and take it to a person that knows about hard drives.
Jan 20, 2010 | Computers & Internet
Disk Error read
This error means there is probably something wrong with the drive itself. I would reccomend having the hard drive replaced. Was the computer new or used?
Dec 28, 2008 | Toshiba Portege 4010 Notebook
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
