Question about HP PSC 1610 All-In-One InkJet Printer
Paper size error
Printer wont print say paper size detected is not supported
  • Anonymous Mar 24, 2014
    I attempt to print, paper is loaded. However it does not detect paper. I have followed all instructions.
    Novelist:
    Scholar:
  • 111 Answers
What that means is that you put in a size of paper that your printer can't use. Apparently, the paper you loaded was detected by the printer and was recognized as being a size it isn't designed to use. HP.com has a web page for your printer that tells you which paper sizes you can use for your printer.
Product Specifications
When the web page opens, scroll down to the Paper specifications area and look for the Paper sizes table. Use only the paper sizes that are listed there in your printer. Good luck.
Posted on Oct 13, 2008
Hp5550 error 41.5 every time I try to print double sided.
Make sure the print driver settings say it is printing the right size of your paper. It may have paper blocking a sensor or the sensor is bad.
Nov 04, 2017 | HP LaserJet 5550 Printer
Paper size detected not correct
What size paper you are using? if you are selected 4*6, you have to use same paper right?, pl clarify
Feb 02, 2012 | HP OfficeJet 7310 All-In-One InkJet...
When I want to make a copy it tells me "Paper size
Good day, Regarding the error message that your getting, that means the paper where you want to print that document is not supported by the printer. Usually you'll the see supported paper size if you click the print option or print setup for your printer. The only way to resolve this is to use the appropriate size of paper like.
You can also try this steps to change size for the documents you want to print
>Open the File menu and click Print.
>Click the Settings tab
>Click on Paper Size. A list of paper sizes will appear
>Select the size you want.
>If none of the selections are suitable, select Custom. A box will appear inviting you to set your
own measurements. Enter the width and length that you want.
>Click OK.
These are the usual paper size use. It's 8 1/2 by 11 inches and the other one that you could use in most printers is 8 1/2 by 14. The first one is known as Letter size, the other one is known as Legal size. Hope this information help in resolving your issue. Have a great day.
May 23, 2011 | HP Photosmart 3310 Printer
My HP printer is getting a error that keeps reading paper size error is detected.What does that mean
This might be due to that the printer in the tray does not reflect the paper size setting on the printer, or the program you're printing with. eg. Maybe you're printing in word, and the page setup size is set to legal size, but you have letter size on the printer.
Mar 07, 2011 | HP Photosmart 3310 Printer
Hp2840 printer error "Too large to print" even with a very small file.
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
http://www.fixya.com/support/t6355639-hp_2640_half_right_side_page
Oct 08, 2010 | HP LaserJet 2840 Printer
Can not print on letter headed paper
probably itsa different size and this is the issue ..cause the actual paper does not have much to do with cause most printers work with all kinda paper *** long as it is the right dimension in format ...A4 in general ...
so ...print your logo on paper that will be detected...you can also make a trial first ...
Oct 07, 2009 | Kodak ESP 5 Printer
It doesn't print It says size paper error
This problem occur when ink head is dirty and also the head cleaning plastic mechanical cleaner is full of jammed color. 3210 model can be opened and the ink head plastic cleaner can be changed. The ink head is the moving part on the metal axel.
Isopropanol is good for cleaning.
Oct 06, 2009 | HP Photosmart 3310 Printer
34 short paper
The printer does not auto detect your paper size and so when your Legal size document was printed on Letter size paper, you get a 34 Short Paper message.
Feb 07, 2009 | Lexmark C510 Laser Printer
Printer is not printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
HP PSC 1610 All-In-One InkJet Printer Logo
447 people viewed this question
Ben Johnson
