Question about GE Profile JTP56 Electric Double Oven
I have a self-cleaning GE Oven, model # jkp06001av, that is about 30 years old. The lower heating element has burned out. I need a part number and a location of the nearest supplier (zip code 30084, Tucker, GA). Can you help
  • 1,543 Answers
Hi. Not too familiar with your area, but you could give BOB BAILEY'S TV & APPL.
5100 Hwy 78
Stone Mountain GA 30087
770 979 1077
Approx. 4.7 miles
a try to get your WB44X200 bake element. (Yes, 30 + years,..... had to go bad into the microfische to find that part number) Part is still available and is rather easy to change yourself.
Posted on Oct 08, 2008
After self cleaning now won't heat up
Self cleaning superheats the oven to burn off the dirt to ash. Unfortunately it can also burn out elements and the wires that are attached to the elements.
Disconnect again and check the timed oven settings. If no go, you need a service engineer.
Apr 16, 2016 | GE Profile JT952 Electric Double Oven
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
168 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
