Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Ink levels my printer shows ink levels empty even after changing cartridges
  • 905 Answers
On the printer reset the ink levels and in the sofware , otherwise the cartrige is to old and just wont register correctly
Posted on Oct 09, 2008
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
I have an HP F4580 printer, and have just refilled both ink cartridges. However the printer won't allow me to print as it thinks the ink has gone. How can I reset my printer to display ink cartridge...
Often they have a chip mounted on the cartridge which monitors usage and when it determines that there is no ink remaining, it will disable the printer. Some companies sell compatible cartridges and reset the chip counter. But unless you reset the chip, even tho the cartridge is full of ink, the chip still disables the printer.
Feb 26, 2011 | Office Equipment & Supplies
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Printer will not print. It is connected to the computer with a USB and it is connected securely. It is not correctly reporting ink levels even though I replaced the empty and the low one . It still shows...
most of the inkjet printers are like the same problems. when you are replace the cartridge use origional. dont use gray and refill cartridge. the printer head sensor cannot regognize these kinds of cartridge. so if u use the origional one it will show the ink level.
Dec 01, 2009 | Brother MFC 240C All-In-One InkJet Printer
Canon ip2600 reset problem, when i change the cartridge sin my printer the ink levels dont reset and it stops printing can any one help me with how to reset the ink levels please
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
The printer shows empty cartridges but it will printing.
Oct 19, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I just put a new cartridge in my dell AIO 946 printer but it still says the ink level is low.
well this always happens with all printers. I have a HP, in the beginning when I first bought the printer, it came with a ink cartridges, it showed the levels. But after the ink was all gone, it showed empty ink levels. The best way to solve this is to ignore this. When you see that your paper is poorly printer, then your ink cartridges need changing.
Aug 28, 2009 | Dell 946 All-In-One InkJet Printer
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer level gauge shows cartridges aas empty even when they are
hi,
many times the ink gauge is not true, if u wanna see the actual level of ink, try to print the self test page..........
regards,  raj_p5983
Jan 21, 2009 | HP Photosmart C5280 Printer
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
Ink levels are not responding.
Did you buy a brand new or remanufactured/refilled cartridge? Some cartridges will show empty, even when full.
They want you to buy brand new, brand name ink!
Jan 05, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
243 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
