Question about Hansol H550 15" LCD Monitor
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
  • Margaret Booker Oct 08, 2008
    Have already tried this but was willing to give it another go, alas , I had the same result as previous try.
    Thanks anyway!
    Dizzyme
  • Margaret Booker Oct 09, 2008
    Thanks for another option. Still no joy!
    Dizzyme
    Champion:
  • 293 Answers
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Posted on Oct 08, 2008
  • Cj T
    Cj T Oct 08, 2008
    Dizzyme,
    I'm back... Have you tried open your monitor on screen display and check the volume control make sure it is not setting at 0 or mute. Still no lucks, then open the back cover and check the speakers cables are not losed.
I am having problems with our daughter's tv. The volume isnt working now even though the picture is fine?
Have you looked at the headphone jack? Sometimes a set is left plugged in and sound wil not come out of speakers.
Also, look at cable box. It can sometimes have a separate volume control.
last, if you plug in a set of headphones and you hear sound, pick up a pair of inexpensive powered speakers and use those.
Jul 10, 2014 | Bush 5693D 24" TV
Logitech Z313 Sound System Failure
On the basis of your description, you can conclude that your Logitech speaker system has failed.
Mar 18, 2014 | Sun -115H Computer Speakers
After unplugging my computer for a week, the sound on my CLT 190 LX computer monitor didn't work, even though I tried several sound sources from online as well as MP3s on my computer. The headphone...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
May 10, 2011 | Computers & Internet
I've had my monitor for about a year now, and its worked fine. But after last night my sound stopped working. I put in a pair of headphones, and they didnt work either. I know its not muted, and my cpu...
If you connected the headphones to your audio out jack on your system, and no audio, then the issue is with the computer, not the Monitor's speakers. It is possible to mute the speakers with a hot key combination, so I'd be throughly checking the audio and volume control settings
Sep 30, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
No sound on monitor speakers
You have installed a new sound card however you won't be able to use the monitor speakers unless there is a seperate cable that you can plug into the headphone jack. Or you can get some speakers and plug them into the headphone jack.
May 29, 2009 | Aureal 2 Channel PCI Sound Card
Not able to hear sound out of my monitors speakers
Not Necessarily Sounds Like The Speakers Are Hooked Into The Wrong Jack.
Dec 30, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Cannot hear sounds through headphones
if you are able to hear normally from the speakers and not from the headphones possible reasons could be:
the audio is muted or very low
there is a mute switch on the headphone that is turned on
the headphone is not firmly plugged in or is in the wrong site eg microphone
hope it helps
please inform if it helps..
Nov 01, 2008 | Acer Aspire 3680 Laptop
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
No Sound in any mode
I had the same problem... but I knew that my 2 yr old had been playing with the headphone jack on the BC-150. Evidently, the system thought that headphones were still plugged in to the port on the front right of the unit, even though none were present. The solution that worked for me was to take some headphones, plug them COMPLETELY into the system (another set of headphones would not insert all the way, so I found a new set and used those to completely insert into the headphone port) while playing a CD and listen for a few seconds and then simply unplug them. Viola! Sound came back. Hope this helps.
Dec 24, 2007 | Sony DAV-BC150 System
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Hansol H550 15" LCD Monitor Logo
166 people viewed this question
Top Hansol Computers & Internet Experts
Cleverer2
ray gallant
Andre van Wyk
Andre van Wyk
Level 1 Expert
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
