Question about Garden
How to fit brushes to b+s 12 hp starter motor about 8years old
How do hold the brushes back to slide them over the commutater?
  • 48 Answers
Sounds like you removed the rear cover instead of dismantling the starter from the gear side- good luck putting it together that way - you need to dismantle from the gear side so you can put the armature into the brushes with no prob -
Posted on Oct 17, 2008
Where I can buy part for brush cutter kubota d170
Contact Kubota directly determine availability and source.
Jan 14, 2017 | Kubota Garden
Remove motar from whisper flo pump
Replacing your pool pump motor
Gather the following items.
Phillips and flat head screwdrivers
Circuit tester
Dry towel
Step One
First, make sure that the power to the pump is turned OFF. This means turning off the breaker at the panel box and not just the switch at the pump.
Step Two - Removing the motor assembly
Remove the four hex head bolts which hold the motor assembly to the pump/strainer housing (These bolts may not be visible).
Slide the motor assembly out of the pump/strainer housing, exposing the diffuser. Pull the diffuser of of the seal plate, exposing the impeller. (The diffuser may remain in the pump/strainer housing. To remove, pull it straight out of the strainer housing.)
There will be a gasket or O-ring sealing between the motor mounting bracket and the strainer housing. Inspect this thoroughly and replace if necessary. An economical option would be to purchase a Go-Kit which includes the pump shaft seal and all necessary o-rings, gaskets and lubricant for your pump.
Step Three
Now, you can lift up the motor with bracket attached to get to the wiring more easily. There may be a bare copper ground wire attached to the outside of the motor that you will need to disconnect. Remove the cover plate on the back of the motor to get access to the wiring. You should have one green wire that is the ground wire and two other wires that are your leads. The lead wires should be black and white but could be any other color except green. Disconnect these wires (they may be attached to a screw, held down by a nut, or clipped on with a terminal clip).
Step Four
Next, you will need to disconnect the conduit (sleeve covering wires between motor and switch or junction box). This usually means unscrewing the compression nut that is screwed on the adaptor which is screwed to the motor. After unscrewing the conduit compression nut, you can pull out the wires from the motor. If you wish to reuse the adaptor, unscrew it from the motor.
Step Five
Now you must remove the impeller from the motor. Remove the volute covering the impeller if it is there. (Some are screwed on). You will need to go to the opposite end of the motor and pop off the plate covering the shaft. The shaft will either have a slot in it for a screw driver or is flattened to allow you to put an open end box wrench on it. This will allow you to unscrew the impeller. You will unscrew in the direction that is opposite to the direction that the veins point at the outside of the impeller. This is the same direction that the motor will rotate the impeller. This may look backwards but the water comes into the center of the impeller and rolls off the veins away from the impeller by centrifugal force. As you take the impeller off, be sure to note how the pump seal is positioned. We highly recommend replacing the pump seal with the purchase of a Go-Kit when replacing the motor.
Step Six
Now you can see the bolts that hold the motor mounting bracket to the motor. Unbolt these, separating the motor mounting bracket from the motor. You are ready to reverse the process to install the new motor.
Step Seven
Important Notes on Reassembly: DO NOT touch the ceramic faces of the seal; This may cause the seal to burn up and leak. Be sure to tighten the impeller completely. Be sure to wire the new motor for 110V or 220V depending on what you have. This may be a simple switch in the motor or you may need to use the wiring diagram on the motor to set for the proper voltage. (Black tracer means the white wire with a black line corkscrewing around it.) Be sure to put the volute back on, aligning properly. Be sure to reconnect the bare copper ground wire to the ground lug on the new motor. When tightening bolts, alternate tightening a few turns at a time to seat evenly or the pump may leak. Fill the strainer housing with water before starting the motor to prime system and prevent damage to seal and impeller.
More Helpful information on how to replace a pool motor
Shaft Seal installation
Clean and lubricate the impeller hub shaft and pump housing seal recess with a dilute solution of non-granulated liquid-type soap
Gently wipe the black, polished surface of the spring seal assembly with a clean, soft cotton cloth. Press the spring seal assembly onto the impeller hub with black polished surface facing away from impeller.
Gently wipe the polished face of the ceramic seat with a soft cotton cloth. Lubricate the O-ring on the ceramic seat and press it firmly and evenly into the recess of the seal plate with polished side facing out.
Place the seal plate onto the motor mounting bracket aligning the positioning lug and guide.
Replacing the impeller and diffuser
Slide the motor assembly, with the diffuser in place, into pump/strainer housing, being careful not to dislodge the diffuser.
Fasten assembly to housing using the four bolts. (Be sure housing gasket is in place.) Tighten alternately and evenly
Oct 03, 2010 | Garden
What kind of carb cleaner should I use to clean my lawnmower carb
mower fuel in an ice cream container
(unleaded petrol )
a new pastry brush or paint brush
air compressor would be handy to blow the rubbish off before opening up the carby
and blowing the jets
Jan 13, 2017 | Garden
I have a 26inch Craftsman's snow blower that won't turn over, I tried the rope and electric starter and it won't turn.
If motor is not turning it is possible that it is seized.up.
BTW there is a significant difference between not turning over and not starting.
Jan 11, 2017 | Electric Garden
How do you replace the hour meter in a caterpilar 420D Backhoe?
most hour meter have a 2 wire system connection at the back with either a plug on or nut on bolt connectors
they are held in place by a large "U" shaped bar that goes up from the back of the gauge and presses against the dash or mounting panel
remove the nuts holding the bracket and the gauge comes out the front of the dash or panel
if space to the back of the gauge is limited you may have to remove the dash first
Jan 08, 2017 | Garden
I have a Yellow Stone APW-150a pressure washer bought in 2005. The hose is cracked at the fitting that attaches to the washer. Can it be replaced or repaired?
Though I have never heard of Yellowstone appliances, I am pretty sure there is a way to get replacement parts from the company spare parts department or from other sources who sell these pressure washers. If not, try the Internet, or try the Speed shops where they sell these to people who pressure wash their cars/trucks. I am also sure there are other hoses not necessarily for the Yellowstone brand but fit perfectly well on them. Find out where they sell other brands and take your washer to them, ask them if they can sell you a hose with the right connectors to fit your washer. No salesperson can refuse to sell you a good bargain.
Jan 30, 2015 | Garden
My starter string broke on my troybilt lawn trimmer, how do i fix it
Disassembly of the covers and controls to that point will be needed. It takes a little bit of work, then you have to preload the spring tension on the recoil unit BEFORE you install new rope. A good little bit of labor involved....somewhat mechanically inlined?
Aug 27, 2010 | Troy Garden
Pentair whisperflo 3/4 hp left running over an hour with no water
Sorry to have to tell you but you are going to have to either have your pump rebuilt or replaced. Sounds like you baked the plastic impeller and maybe did even more damage. These pumps require water in order to keep cool.
Jul 02, 2009 | Garden
Patio umbrella tilt locking hinge broke
Need a fix for my patio umbrella the wind snpped the push button tilt mechanism.
Mar 31, 2009 | Garden
The pump lost vaccum, now the motor shut off and pump only hums.
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Jan 15, 2009 | Garden
Garden Logo
96 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
