Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
I am a 100% novice when it comes to electronics, but will not hesitate to give it a go! I hve a new HDTV(Samsung) and a 6yr old Sony DVD/VHS player. TV channels show great pic! (I have not hooked up any high def devices or connections yet!) However, I hooked up my DVD player to the HDTV, using Monster component cables(all connections are accurate) grn to grn(y) blue to blue and red to red. I attempted to set my clock on the DVD )setup)and no display or pic. I was told to depress the source button on the TV to see if it picks up the DVD. I did and it gives error Component 1-weak or no signal. I just realized though. I have not hooked up the audio red/white connections..some diagrams show it used..some dont so I assumed I did not need it..guess I do, but would that keep me from having a pic on the TV from the DVD and the TV not detecting the device? I also do have an older JBL receiver I will eventually be hooking up and will be using the Component cable..NOTE- neither the DVD player nor the receiver has a HDMI connection.
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Posted on Oct 09, 2008
Noice from my samsung 50 projector
Color wheel is located next to lamp housing in TV and to replace color wheel, service manual of TV is required as well as expertise, tools etc.
Basically it is qualified TV tech job and novice can damage TV internal.
Thanks.
Aug 31, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Color Wheel installation
You can purchase color wheel of Samsung HLT5075SX from Part Store and I would recommend to have qualified TV tech for installation. it is not advised to novice to get involve in such kind of repair that can damage TV.
Still you want to repair it by yourself then download service manual copy of same TV from HERE for small fee that has proper info.
Aug 05, 2009 | Samsung Televison & Video
Dell W4201C half black screen
It should be easy enough for a Novice to fix.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 03, 2009 | Dell W4201C 42 in. Plasma HDTV
Sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
Mar 25, 2009 | Sony KDF-50E2000 50" HDTV
How to hook up everything!
I have similar equipment.
You should use an audio digital cable to connect the bluray to the Yamaha receiver and another digital audio cable to connect the HD box to the Yamaha receiver.
Hope this helps.
Dec 23, 2008 | Yamaha HTR-5650 Receiver
Blurry pics Samsung S860
Try it with DIS function on.
You take a shot, in average daylight conditions in 11 modes, See which settings give good pictures and use those settings.
Probably the best setting for the digital camera is AUTO(green),for a novice
Mar 30, 2008 | Cameras
How to record onto dvd/vcd
Dear Krishna,
Its not easy task that a novice become master in few steps. Editing of a movie needs alot hard work.
Mar 25, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Blue shadow
You have a bad light engine or in Sony TV sets, it is called an Optic Unit Block Assembly. This is a very expensive part and should not be attempted to be replaced by a novice. Call an authorized Sony repair place to have this repaired. Good Luck
Sep 14, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
TV does not turn on
Most likely a bad flyback transformer....circuit board pull +
xformer R & R not for novice.....Part # 1-453-285-21.........T.
Apr 25, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Electro Med Services...
