When I start the computer up the emachine logo comes on momentarily then a "no signal" box comes up. Unable to do anything after that.
It could be a BIOS setting causing this particular problem. You can reset your BIOS to default settings by:
3. Turn off the PC and move the jumper over to the open pin and the center pin for 5 seconds then move it back to its original position.
This will reset *********** board to its default values and will more than likely cure the problem you describe.
Note that you may have to reset the time and date in your BIOS setup once this procedure has been carried out.
Let me know if you have any further queries or problems regarding this matter.
Best wishes,
Graemevm
