Question about Palm Zire 21 Handheld
The Palm doesn't recongnize my IP address and vice versa so I am unable to sinc with either my hand held or my pc?
No I haven't been able to get the problem fixed, I don't know how to enter the IP address into either my lap top or my desk computer. And the Palm doesn't recongnize either one to sinc
Posted on Oct 09, 2008
No, I'm not willing to pay for you to fix my problem, because I feel that after paying nearly $100.00 for my Palm, that you should at least help me get it so I can use it properly, And since that doesn't seem to be where you are. forget it. Unless you are willing to help me get started with my Palm free.
Thank you
Test vostro 3350
All you need to do it to change your WiFi broadcasting channel and IP setting. Open up your router`s setup by entering the default gateway IP, enter username password if prompted first ->go to Lan setting and make sure that you DHCP is enabled then change your starting LAN IP address from 192.168.0.1 to 192.168.1.1 or vice versa.
Oct 02, 2013 | Computers & Internet
Sharp MX-2300N Color scanner can't find network
Drivers are for print functions only (or twain scan via USB). Check for bad cable, port, or jack. Could be another device on the network is being handed the IP of the copier via dhcp (or vice versa) can you ping it from a workstation? I have also seen the dell network assistant utilities on some dell workstations cause issues like this.
Jan 11, 2013 | Sharp MX-2300N Color Copier
What are the static ip for leased lines
You have not provided enough information to answer this definatively. However, one possible answer exists, if this relates to leased lines from a service provider or telephone company. Leased lines involve a physical connection and a network layer logical connection. At the physical layer, there are no assigned IP addresses, just devices that transform analog to digital signals (and vice versa).. The installation person should have checked signal conductivity as part of the service. The next layer up (TCP/IP), has IP addresses, either given to you on some paperwork, or via dynamic IP Address assignment request. If the service promises a static IP address, then your paperwork (for example, setup instructions) contains any access authentication (required); a group of 4 or 6 numbers, separated by periods; and at least a 2nd set of 4/6 numbers designated as your default route IP. Otherwise, you may have to turn on DHCP and let your external router port retrieve your assigned (static) IP address from the network device at the other end of your network connection. The returned IP address is your assigned static IP address. Just make sure it is not 10.x.x.x, or 127.0.x.x, or 192.168.x.x. Those address ranges are not routable in the larger Internet space.
Feb 08, 2011 | Dell Computers & Internet
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
I have the same problem! I use to get on just fine.
Try doing a hard reset. Make sure you have everything backed up on your pc since you will have to do a hotsync once you do the hard reset. OK to do a hard reset do this:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen2.gif.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Sep 18, 2009 | Palm TX Handheld
Hot sync
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(2630)
With your Palm Zire 21 connected to your pc, go to the link above and run through the Palm HotSync troubleshooting dialog to see if any results come up that will solve your issue.
HotSync issues are unfortunately difficult to pinpoint and often will require a software update or patch to resolve issues.
Good luck with it!
OpenSource13
Apr 08, 2009 | Palm Zire 21 Handheld
Linksys router 160N will not work.
You probably have encryption turned on in the router, as you should... But your wireless NIC in your laptop may have the wrong settings for encryption set... Compare the two and change your NIC to match that of your router... You may have to know the passphase or password depending on your level of encryption... If by entering a valid IP by hand and it still did not work, may mean that your DNS server IP address(es) werent set correctly, you should use the router's IP address as your default gateway and primary DNS server IP address, since most likely your router is connected directly to your ISP modem... Hope this helps!!
--Joshua79
Apr 04, 2009 | Linksys WRT160N Wireless Router
Palm Treo synchronize calendar daylight savings time
You need to go to your phone carrier support page, or to Palm.com and download the daylight savings time update.  You SHOULD keep network time checked unless you don't want to pull the proper time from your carrier, such as when you are out of town.
Mar 24, 2009 | Palm Treo 700w Smartphone
Lost data on palm zire 21 hand held
To the best of my knowledge, if you don't have a pc backup, you are out of luck.... Sorry to be the bearer of bad news... Download the Palm Desktop Software and start to use it if you decide to continue using the Zire 21. The Software is free from Palm.
Sep 25, 2007 | Palm Zire 21 Handheld
I cannot complete hotsync
Right click on the HotSync icon in lower right hand side of your computer tray, uncheck Network. Your Palm is attempting to perform a Network HotSync. Only Local should have a check mark beside it.
Sep 12, 2005 | Palm Tungsten E Handheld
Palm Zire 21 Handheld Logo
76 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Vuk B
Mister Danger
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
