Question about GPS
My Garmin Nuvi 360 we bought approx 1.5 to 2 yrs ago is now having trouble all the sudden finding satelite reception. We just had a major storm come thru our area and it seems to have happened just since that storm. We have tried the reset button...what else can we do?
  • 2 more comments
  • JMont1 Oct 25, 2008
    Garmin 680 ~ 18 months old. Antenna cannot locate satellites, Germin recommended update s/w then reset using the hold finger in bottom right cornar. No help so Garmin offered repair for $225.
    This post had me hold upper left corner that got me into maintenance mode. Followed instructions and did not repair problem.
    Performed the hold wire to external antenna connection and it started locating satellites. Went to Circuit City and got external antenna to resolve issue. Seems Garmin has an issue that should be addressed better than $225 for customers. Thanks for your help.
  • Ellen Ransom
    Ellen Ransom Nov 03, 2008
    Same problem but with the 660.
    Nothing seems to help. Thinks I'm in Kansas.
    Garmin's solution is to send them $225.
    Hate to give Garmin $225 to fix/replace this unit, it's the second one that failed in this way. I love the features of the 660, would like this frustration of having a $800 investment down the drain solved without giving Garmin another dime. Or at least only paying for parts.
  • Anonymous Nov 30, 2008
    I think it is a software problem with pirated maps ext
  • Anonymous Apr 15, 2009
    I have the same issue with my 360. It looses satellite reception during my trips and never finds it again. My friend found an external antenna for his and told me to get one. He hasn't had a problem since. I've heard that this is very common for Nuvi models with antennas that flip up and down. Eventually the wear and tear affects the connection of the antenna to the gps and in time will no longer work.
    I plan on buying an external antenna soon. Hopefully this will rectify the problem.
  • GPS Master
  • 2,130 Answers
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there
while pressing the on/off power button. Keep holding your finger there and a window
should pop up asking if you want to go into maintenance mode. Select yes. There is an
option called "clear user data". Select that option. It will not erase your favorites.
It will however, erase any corrupted satellite data and will default you back to some
factory settings. This will clear some of the memory allowing your Nuvi to collect new
satellite data. Your Nuvi should reboot and it will ask you a couple questions like,
timezone, language. Please select the proper settings.
Make sure the antenna is up and that you are outside. On the main screen, you will see a
satellite bar graph in the upper left-hand corner. Touch the bar graph and you should
get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you
should see horizontal hollow bar graphs appear on the right. Eventually they will turn
solid blue. This indicates they have downloaded the proper data from the satellite. When
you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin
to show improved accuracy and your Nuvi will then work as it should. This entire process
make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you several minutes later, if you are
indoors. If your outside, select no. It will then ask you if you have moved 1000 miles
since your last use. Select yes. This will cause your Nuvi to start looking for
satellites, trying to locate your new position. When you perform a factory reboot, your Nuvi thinks it's in Kansas (Garmin HQ) and so it needs to be told to look for new satellites.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There
is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no
longer use its internal antenna and it's now always looking for an antenna at the
external antenna port (the gold connector on the side of the Nuvi antenna). If you have a
piece of small wire, a couple feet long, you can insert that into the center lead of the
external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes
and your Nuvi will lock.
I haven't been able to identify yet, which part has failed. I am working on that.
However, if the piece of wire works, you can always go on eBay or a retail store and
purchase an external antenna for your Nuvi. They are magnetic and can either stick to
your roof or any metal surface within your vehicle.
Here's another way to determine if your antenna has failed and will have to be replaced:
At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then
press "about". There is a field marked "GPS S/W". There should be a number next to it.
It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS
is communcating with the antenna receiver. If you see "0.0" then your antenna is
defective and there's no way to repair it other than replace it.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Oct 10, 2008
    Scholar:
  • 40 Answers
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Posted on Jan 02, 2009
My garmin gps takes ages to find the satelites - up to 3 hours, even under clear skies with no overcast
Try hard resetting which will require you to press a small button on the back or bottom of the device with a paper clip. Hold it down for five to ten seconds. Try and see how long it takes GPS to acquire satellite reception. You can also try the customer service number US Toll Free: 1-800-800-1020 to inquire further.
Mar 03, 2011 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 610 not Acquiring satelites. it was working fine and while driving suddenly said something about poor reception, now nothing
Its sounds like your GPS's internal receiver is broken, you may be able to fix this with a firmware update but it is likely you will have to purchase an external antenna for your GPS to be functional.
Hope this helps!
Dec 10, 2010 | Garmin Nuvi 610 GPS Receiver
First time using my garmin 205W and it only holds satelite service for about 10 minutes
I recommend you replace the firmware and system software using webupdate. Updates in the Nuvi 205 firmware has increased its satellite reception and accuracy.
I hope that helps.
Apr 01, 2010 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 760 loses satelite reception. Tried to reset to factory settings and still having problem.
You may need to buy an additional external GPS receiving antenna. I did for my 750.
Because we love our electronics so tiny, they use an internal antenna. The gold input on the back of it, is for an external antenna available for under $20 from ebay. I used it when I lost reception in NYC, and also in rural areas. The external one has q magnet on it, and you can put it on the roof and have the cord come in your window to the unit (better than arm out window!)
check here - where i bought mine
http://cgi.ebay.com/AMPLIFIED-GPS-ANTENNA-FOR-GARMIN-NUVI-760-750-770-780_W0QQitemZ220265873242QQihZ012QQcategoryZ73348QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
Enjoy, NGK
Sep 03, 2008 | Garmin GPS
Can't get a satelite signal
I am having the same problem. I think that Gramin is not tellimg us something. My signal will come a go, but never stay up for more them one minutes at a time.
Jan 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin 360
have you ever updated the firmware (webupdater @ www.garmin.com)?
Dec 12, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
2,332 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
