Question about Sharp UX P100 Plain Paper Thermal transfer Fax
Fax in memory but when i add paper it stops bout 1/4 of the way
I add paper and hit the memory button. the paper feeds through bout 1/4 of the way and then stops. then the memory message appears. and i have to open up machine and pull out the sheet of paper then it does it all over again
  • 100 Answers
Either the memory in this machine has failed or it needs cleared out and I dont have the users manual for this. Sorry best i can do.
Posted on Jan 08, 2009
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
I can send faxes but I cant recieve any.
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Cannot send fax until I activate the Memory button, want to send "Direct"
Hi rlandriani,
There should be a setting under user paramaters in the menu section that will allow you to change the default "memory on" setting to "off".
The user parameters set on the menu currently can also be printed for you to go through at your leisure so that you can customise the machine to your own personal prefferences.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Paper feed
Is your paper right in slot with grey flap over top of paper feeding into slot.
Apr 08, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Fax scanning stop paper feed 1/4 way
Sounds like it got set to "immediate" transmission somehow, rather than "memory" transmission -might be as simple as a button on the operation panel, but I'm not a "canon" guy.
You can get the manual here if you don't have one:
http://www.canon.ca/english/index-softwaredownload.asp
Select "office products", and follow the prompts
Jan 30, 2008 | Canon LC-3175 Laser Fax
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
Outgoing Faxes
THE MACHINE IS ET TO DELAYED TRANSMSSION (MAYBE THROUH TOLL SAVE BUTTON ) OR OTHERWISE, PLEASE CLEAR THE MEMORY STORED MESSAGES FOR DELYED SETTINGS, THE PROBLEM WILLL BE RESOLVED IMMEDIATELY HAPPY FAXING OMNIPRESENT
Jul 31, 2006 | Samsung SF-830 Plain Paper Laser Fax
Sharp UX P100 Plain Paper Thermal transfer Fax Logo
139 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
