Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Icemaker in Admiral side by side refrigerator/freezer stopped working
We had a big storm and power was out 7 days. after emptying freezer of ice and putting 'arm' back down, once power came back on - it only makes one harvest of ice per 24 hours. I looked in back of refrigerator at water line to the ice maker and there's a big bubble in it. I have changed the water filter (because it was time to). Still, no ice. what should I be doing now?
  • 958 Answers
See if you can bleed the air trapped in the water line to the ice maker. if air is trapped, water would not be flowing and it would take only a few seconds for the solenoid to be open to let water flow.
see if you can hot wire the solenoid to let water and air out of the tube long enough to bleed the air and hopefully, the ice maker would work continuously.
tnx 4 using fixya,
Posted on Oct 08, 2008
How do you remove icemaker to check if water tube is frozen?
the ice maker is finished. get the ice maker model number and refrgerator model number and buy/ install a new one. It would be a good idea to replace the electric water valve to the ice maker as well.
Feb 07, 2014 | KitchenAid Architect Series II KSRJ25FXMS...
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice/Water dispenser not working correctly
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker has stopped working. It was fine 3 days
check water valve or icemaker valve is at the back of the unit
Apr 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
No water is going into the trays
check water valve or filter icemaker befor calling service see if you have frost build up in freezer
Apr 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
280 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
