Question about Electrolux Kitchen Ranges
Edb705w fan oven element burnt out - replaced element - oven stil not working ?
  • billo1200 Oct 09, 2008
    Bingo ! ... many thanks
    President:
  • 1,462 Answers
Have you reset clock after turning off to repair? you may have it set to auto
Posted on Oct 08, 2008
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
Bosch fan oven element replaced because old one was burnt out. fan working fine light coming on but element wont heat up
It must be a faulty thermostat as well that sometimes happens when an element blows.
Dec 12, 2010 | Ovens
Neff fan oven dead. Where do I look next? I've
this could all so be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 17, 2009 | Neff U1721 Double circotherm Electric Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Hi my Smeg dual fuel range no longer works on the fan electric oven. The fan runs but get no heat. Is there an element specfically for the fan oven
YES THERE IS AND IT LOOKS LIKE THE ELEMENT HAS BURNT OUT DUE TO NORMAL USE OVER TIME , REPLACE THE ELEMENT AND YOUR OVEN WILL BE LIKE NEW .
Nov 16, 2009 | Kitchen Ranges
Neff 1721 0ven element not working??
did you replace both fuses, if its a 240 volt element check the other fuse on the other leg of input power/120 volts + 120 volts = 240 volts
Oct 05, 2009 | Neff U1721 Double circotherm Electric Oven
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
Kitchen Ranges Logo
100 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
