Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
PC can't find my speakers
Had a PC repaired doesn't recognize my speakers now!
  • 3 more comments
  • junesidsines Oct 08, 2008
    Windows media can't play my music as it thinks no speakers are connected...there are speakers which are working fine with my webcam...this came about after having a new graphics card and reformat. How can I fix the problem?
  • junesidsines Oct 12, 2008
    Hi, Did as you advised and checked device manager and found yellow question mark by something in "Other devices" scan.....Properties showed it to be Device Instance Id.....details were as follows. USB\VID_043D&PID_0093&MI_00\6&60033DF&0&0000
    I don't know what this means...does it mean anything to you?
    Appreciate the help siawolf - June.
    If you mean graphics card it's NVIDIA GeForce 5200....or is it something else...this isnt listed in the sounds video and games controller drop down list.
  • Anonymous Dec 03, 2008
    same problem but i reset my PC
  • Jeff Strader
    Jeff Strader May 11, 2010
    click Start-settings - controll panel - double click on "system" when it opens select the hardware tab at the top, then select "device manager". look the for your sound card. If there is a yellow ! or? next to your sound device or any device for that matter, it has no driver installed or a bad or corrupt one
    is functional correctly.
    please post what you find and i will help you further.
  • 749 Answers
You need to reload the sound drivers, its not the speakers, but lets check just to be sure.
check the power adaptor going to the wall outlet and speakers (are the speaker powered and light on when you turn them on and are they connected to the computer, ime sure you've checked this already.
now lets see what your computer says: this is for windows XP, let me know if your running another operating system.
follow me---
1. click START
2. click SETTINGS
3. click CONTROLL PANEL
4.double click on SYSTEM
5. click the HARDWARE tab at the top
6. click the DEVICE MANAGER button
this will show you a list of all the hardware in your computer and the if one of these listings has a yellow exclamation point or question mark next to it, it is not working properly.
what you are looking for specifically is one called "sound , video and game controllers" OR a sound card that is listed under unknown device. this shows that the wrong driver is present or has been installed incorrectly.
post your findings here and your model of video card from the settings section you were just in. if you have a box the video card came with , give me the info from it.
Posted on Oct 09, 2008
Multimedia audio controller:
PCI\VEN_10B9&DEV_5455&SUBSYS_810D1043&REV_10\3&61AAA01&0&20
PCI Simple communication controller
Video Controller
this are the details of my other devices that has an exclamatory point...
Please do help me...
Posted on Sep 26, 2012
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
It will not recognize my sound bar the section for turn off speakers are grey out and it also doesn't see the sound bar.
If the sound bar is missing and speakers are grayed out--if using a box means a setup option there is causing this.
If in set means a similar issue---most likely is a cable box if used is disabling the sets menu for this.
You may if using a box want to disconnect all connections to the set and unplug both set and box to see if after a wait both will reboot when plugged back in.
As a last resort with the model number call Toshiba customer service.
Apr 01, 2012 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
Why doesn't my computer reconize my speakers
You need to download and install the drivers for your audio, it's not that the speakers aren't recognized, it's the sound card, or on-board audio, whichever you have, that's not being recognized.
Jan 20, 2012 | Computers & Internet
My laptop speaker is not working
Hi solomonowobu...
Right click on the speaker icon on your desktop and make sure the volume is up on your computer and not down in the muted position.
Left click on the speaker icon on your desktop:
A window opens and you will see two choices...select Volume control, when the window opens make sure none of the mutes are checked, if they are uncheck.
If this doesn't solve your problem you may have to download new audio drivers for your computer, and it that doesn't clear the problem, then you will need to send it to get repaired as it is a hardware problem.
Please take time to rate me
Sep 04, 2011 | Computers & Internet
Audio not coming after installing driver
First, make sure you installed the correct driver.
Then go to the control panel and under "sound" check to see if the speakers are muted. Also, check the speaker volume.
Go to the sounds tab and see if, when you click an event that has a sound assigned to it, the little arrow for preview is dark. If it is dark and the volume is up and not muted, you should hear sound. If it is grayed out, you your computer doesn't recognize the sound card or drivers.
Aug 30, 2011 | Lenovo 3000 N100 0689 Notebook
No audio from PC
You just need to download the appropriate audio driver for your motherboard. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with the motherboard of the computer.
For those who doesn't know how to access Device Manager, please follow the steps below.
For Windows XP:
Start -> Run -> Type devmgmt.msc (in the box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
For Windows Vista and Windows 7
Start -> Type devmgmt.msc (in the start search box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
Hope this helps.
Jul 17, 2011 | Computers & Internet
Boston Acoustics VR960 Crackle
I just finished repairing one of my VR960 units with a similar problem. My problem was that the sub would crackle no matter what input level. After changing a few of the active components, I finally discovered it to be a capacitor which was faulty. Anyway, I replaced the three 100uf 25V capacitors on the main board and all was well.
Good Luck.
Jul 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Boston BA745 speakers bought. how to install drivers or whatnot on XP. Computer not recognize new speakers.
Mine dont work my pc wont recognize them. they were previously installed and now the driver isnt recognized. how do i fix it? do i download something?
Nov 25, 2007 | Boston Acoustics BA745 Computer Speakers
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
2,940 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
