I turned on "Compress drive to save disk space" in the Properties window for my C: drive since my hard drive is running out of space. After that utility ran, the resolution on my monitor was changed to 800 X 600 and I can not make it any higher (it won't allow me to slide the screen resolution arrow to the right at all)
  • 749 Answers
Sound like the video driver has been changed or altered. here how to check:
click start-settings -controll panel
once it opens double click system, when that opens select the hardware tab, then click on device manager. look at your video adaptor for any yellow ! or ? or *. if one of these is present you will need toinstall a current driver for the video adaptor.
Posted on Oct 08, 2008
How to fix tfght compressed without windows 7 disk
1. Start your computer from the Windows 7 installation DVD or Repair CD.
2. Select Repair your computer.
3. Load driver.
4. Go to Computer and right click drive where Windows 7 is installed.
5. Select Properties and uncheck "Compress drive to save disk space".
6. Close and restart the computer normally.
Jul 22, 2012 | Dell Inspiron Computers & Internet
Disk full error on file save...
It seems that you Hard Drive is full. You may either choose to upgrade the Hard Drive, or you can compress or even delete some of your data. There are also programs that will search for duplicate files on your system. This website is one example of that. http://www.easyduplicatefinder.com/
I hope I answered your question. Have a great day.
Feb 28, 2011 | Computers & Internet
My d drive says it is 99% free space but it has 4.53 gb how do i get more gb
Your D drive is usually for system restore. Insteed of system restore disk the manufacturer will partition a drive and place the installation data in the D drive. You should have a C drive and this is where you want to focus on. Delete unwanted pictures , music, and other unwanted files. Movies will really use a lot of drive space.
Nov 03, 2010 | Compaq Presario Notebook
Does storing a lot of pictures on my PC cause it to run slower?
It could, depending on how large your hard drive is. Side note, if these are important, back them up so you won't lose them.
One way to save space is to put your hard drive in a compress mode.
Go to start, computer, select the hard drive, right click then under properties click the box that says "compress to save space". It will save space and also help it run faster.
Oct 17, 2010 | Dell Dimension 4600 PC Desktop
Can I increase disk space for Presario F762NR notebook? And if so..how. Thank-you
You can compress the disk and gain a little room which might meet your needs, otherwise you can buy a new disk and install it. I have cloned many laptop disk drives onto new ones. It does take some special cables and and a desktop computer to do however.
Before I do either, I'd try a disk clean up. Turn system restore off then back on to delete all the SR files. Down load CCleaner and run it against the disk and run the registry cleaner.
http://www.piriform.com/ccleaner/download
Disable Hibernation and delete Hiberfil.sys, if the space problem is critical on your System Drive. Its a hidden file on the root directory of your system drive. Open Control Panel. Type Hibernate in the search bar. Select turn Hibernate On / Off.
If you want to try the compress, double click My Computer, right click on the C:\drive, PROPERTIES, check Compress this drive.. This will take awhile so don't turn off the computer or let it shut down. Some say you should not compress the windows folder but I've never had a problem and they slow down is almost not noticable.
Aug 04, 2010 | HP Compaq Presario F762NR Notebook
Recovery disk almost full on computer ,how do i transfer or get more space on it
Good day Sir, (suggestion only) in the properties of your hard drive put a check on the box compress drive to save more disk space. also try to run
chkdsk.
thank you.
Jul 25, 2010 | E-Machines Computers & Internet
My lab top hard memory is parted in c and d and I am running out of space in c drive. How to put them together
1. Go to the Start menu and open Control Panel
2. Select the System and Maintenance option if you are using the Control Panel Home View and Administrative Tools if you are using the Classic View
3. In the Administrative Tools section, select Create and format disk partitions.
4. For Classic View users, select the Computer Management option and select Storage. When done, click Disk Management
5. When the list of your drive is displayed, choose the one with which you want to merge your partitioned drive with (e.g. disk D:) and select Delete Volume.
6. Hence, select your drive C: and the option Extend Volume. You computer will automatically select empty available spaces on your hard disk, and you can alter them if you wish to do so.
Regards.
Sep 30, 2009 | Computers & Internet
Unable to enable ntfs compression in vista (hard disk-"all drives
Compress an entire NTFS volume
warning.png You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
bullet.png Double click on My Computer on the desktop.
bullet.png Right-click the volume you want to compress, and then click Properties.
bullet.png In the General tab, click to select the Compress Volume to save disk space check box, and then click OK.
bullet.png In “Confirm Attribute Changes”, click the option you want.
You may have already attempted this but Maybe not....
This error usually happens in Linux but occasionally within windows.
My apologies if this does not help.
May 26, 2009 | Microsoft Windows Vista Ultimate Edition
Bootmanager is compresed and booting is not preformed
Hi their Rak,
Basically, never compress the entire c: drive, ie, don't just right click the c: drive choose properties then check the box that says Compress drive to save space - Really! DONT DO IT - EVER! Especially if running bootcamp.
If you compress the System Folder it will screw up your bootup in Bootcamp, or from Fusion or even Parallels Desktop. If you want to compress your drive (which is a good idea), be selective about it. Go into your c: drive and compress only your Docs&Settings folder and the ProgramFiles folder. Anything other than the Entire 'Windows' folder. If you want to compress any of the Windows folder, again be selective and do any folder other than the System and System32 folders. Leave all files in the root of the Windows folder uncompressed.
When it happened to me (yeah! That's how I know!! Oops) the only way I was able to rectify it was to create another windows boot file in Parallels and uncompress it from that. After that it worked fine. Hopefully others can benefit from my experience.
All the best to the best of you all
Sean
PiDigital.co.uk
Oct 03, 2008 | Computers & Internet
Error Message
If you want to check hard drive space, open my computer and select the details view. OR right click on the drive icon and pick 'properties'
Freeing up space can be tricky. Use the disk cleanup utility first.
Start/Run/Accessories/System Tools/Disk Cleanup. The only caution is "don't compress files!!!"
Then it's a matter of deleting old documents [I back mine up to CD before deleting.] pictures, videos, etc. You can also add space by adding a hard drive and moving big files, like videos, to it.
Aug 14, 2008 | Canon PowerShot A510 Digital Camera
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
