Question about Acer TravelMate 2300 Notebook
Acer Travelmate problem
Hi Fakhri,
I seem to have the same problem with my Travelmate as you and I am very interested how you opened the case/ cover of your Travelmate. I also noticed the solution posted by Pedroc and his approach to solve it sounds quite interesting to me, so want to give it a try. As some of you described, I also realized that the area near the power supply and cooler seems to be the core of the problem and at the same time quite sensible to pressure or slight force.
My main questions to you are:
Which parts of the case or cover did you dismantle?
How did you do it?
Are there also some screws on the keyboard side or only at the back and side in order to get rid of the back cover/case?
Did your case/ cover stick close to the printer plug/ middle area, are the any more screws?
Is it necessary to dismantle the monitor to reach the cooler/ van?
Currently I have problems to get the cover at the back removed. The cover seems to stick in the middle of the case or especially close to the area of the big printer plugs at the back. I thought I removed all screws but could not get rid of case.
I am very thankful for any help you can provide and looking forward to hearing from you.
Best,
Klaus, Germany
kthiel@chicagogsb.edu
Hello , I hope this is not to late
First of all let me update you about my problem and where I reach with it >> sadly the laptop is no more is working and I have it in my store as open parts and pieces !!
Maybe you ask why? well ,, because I discover that the problem is the main board near from the supply ( there is sort of hidden line and wire inside the board these line will cut or damage because of heat and there is no way to connect them again ! )
Regarding your question on how to open the case >>
1- Open and remove everything from laptop like battery cd drive memory etc .
2- You will notes that there is small arrow at the back near from the screw hole open all of the ,, some of them large some are small in size .
3- On the front near from the screen above the keyboard there is a pies you have to remove it by very small flat screw then you will find other 2 small screw underneath it maybe that’s why you can’t remove the cover at back .
4- If I am not mistaken you have to remove the keyboard first then you will find anther screws also
That’s what I remember ,, I wish you good luck
Posted on Nov 08, 2008
  • Acer Master
  • 4,338 Answers
Klaus,
I saw your message and since I have the link to the service manual of your laptop, I figured I would send it to you:
http://www.nodevice.com/manual/newmans/acer/SG_TM2300_TM4000_TM4500pdf/get48658.html
It is free, you just have to register.
You may have to copy and paste this link into you browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 13, 2008
Replace cmos battery
Hi, you can follow this steps: Just Go to Pag. 67, or you could just use this Time Sync Tool, you are only interested on have the time and date correct every time you use your computer.
Oct 16, 2013 | Acer TravelMate 330T PC Notebook
Hi Sara,
I'm Sarah and interested in knowing your exact problem for the product as there can be over hundred types of problems in an Acer notebook.
Thanks.
Jul 12, 2013 | Acer TravelMate 2300 Notebook
Can you show me how to disable bios password on acer travelmate 2350
The BIOS password is a hefty security measure, and consequently, is difficult and in some cases impossible to disable if you do not already know the password that was set. Dell offers a recovery service if you can prove purchase. Acer does not provide any kind of easy solution, but most use a BIOS developed by Phoenix, and you might (and thats a big might) be able to recover the BIOS (a.k.a. wipe the original, which requires a password, and replace it with a 'fresh' one). If you are interested in this endeavor, I came across a handy tutorial if you want to try it out. http://forum.notebookreview.com/sager-clevo/326954-case-you-kill-your-phoenix-bios-bios-recovery-methods.html
May 25, 2011 | Acer TravelMate 2300 Notebook
Acer 507DX Travelmate, need to remove cover/case to install new HD, apart from the dozen or so screws in the bottom, what else holds it?
The hard drive is usually located under a recess plate on the base of the laptop.
If you locate the battery on the underside, the hard drive cover is next to it and is held on with just two screws.
Hope this helps.
Oct 25, 2010 | Acer TravelMate 507T Notebook
How do I fit a replacement keyboard for my acer travelmate 4150
You need to remove the middle cover of the laptop and unscrew a few screw at the lower case. Try the find the logo keyboard at the lower case. I think just this model got screw to remove first to take it out.
Sep 28, 2009 | Acer TravelMate 4150LCi Notebook
The casing to the screen is broken from the keyboard
sounds like ya need a new casing. I have found one for your model on ebay and posted the direct link for you below. Look there for hinges, should you need those. once you get the parts, post back here if you need help changing them.
http://cgi.ebay.com/ACER-TRAVELMATE-3260-LCD-COVER-W-BEZEL-WiFi-Cable_W0QQitemZ270314018341QQihZ017QQcategoryZ31569QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Please rate my solution.
May 20, 2009 | Acer TravelMate 3260-4874 Notebook
Install a new ram card
dude at the bottom of the laptop there will be small covers with a single phillips head screws in them under one of those covers is where the ram is located...
Mar 15, 2009 | Acer TravelMate 2300 Notebook
I have a 2420 acer travelmate that heats up very quickly and does not start up.It reaches the xp window and cuts out.can you help
Can you determine weather the CPU fan is still working? This type of problem is almost certainly your CPU that is overheating.
Dec 07, 2008 | Computers & Internet
Acer travelmate 2300 - power on but as if BIOS did not start
Open the memory cover from bottom of the laptop if you can find. And re-plug the memory chips carefully..make sure it be plug in properly. and try switch on again.
Nov 05, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 272 Memory
I think in this case the second memory slot is under the keyboard.
Mar 17, 2008 | Acer TravelMate 272XC Notebook
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
