Compaq Presario F500 - won't boot up - power and lights etc on, tries to start but cuts out after about a second
  • 4 more comments
  • Anonymous Oct 25, 2008
    same problem
  • Anonymous Dec 28, 2008
    exact same thing.
    It seems to be tied in with either the power or start up mechanism.
  • Anonymous Jan 30, 2009
    same problem here :( HP&COMPAQ SUCKS !! )
    arni22_baby22@hotmail.com
  • DCNZ Mar 29, 2009
    same thing.
  • Anonymous Apr 06, 2009
    same here
  • littlesadie6 Apr 14, 2009
    I have the same problem as everyone else, shuts off....there is a recall on alot of F500 series laptops. Simply go to www.hp.com and type in the model number for your laptop and recall. There is a wireless issue and a powering up issue. I just sent mine in to HP, fixed it for free and paid for fedex shipping! You will have to call them first and I will say it was a little frustrating the person I spoke to didn't speak very good english. Call them when you have the time to wait on hold. Good Luck!
Check out this recall and see if it applies to your model laptop. From what I here, the motherboard may need to be replaced, and may be under a specila warranty.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01480071&lc=en&dlc=en&cc=us&lang=en&product=3441671
Posted on Feb 11, 2009
Tip
Compaq presario Wireless
These are the steps to make compaq presario f500 Wireless WORK!!!!
1.Download (password: kon-boot) Kon-Boot floppy image and extract the zip file to get FD0-konboot-v1.1-2in1.img filef.
2.Download latest version of UNetbootin and install
3. Run UNetbootin, select Diskimage, click the drop down menu to select Floppy and browse for the FD0-konboot-v1.1-2in1.img file.
4. Make sure USB Drive is selected for Type and the drive letter is the USB flash drive that you want to install Kon-Boot. Click OK. It should take a few seconds to finish installing Kon-Boot floppy image into your USB.
5.restart your laptop while the USB is in it.
6.When the compaq logo appears Pres Esc to bring the boot menu.
7.Chose your Flash Memory.
8. then press enter to chose Defult
9.press any key when u get the Kryptos Logic image.
10.then wait tell it finish
11.when u see again the Defult menu take the usb out and restart the computer by holding down the power button for 7 sec.
12. boot windows normally you will find the wireless BLUE and ready to work.
This is made By : Mohammed Abdulhadi (AKA) Hackezier Abdulhadi
Any copy of this article without approval will have legal consequences
Contact Me on:Hackezier@hotmail.com
on Oct 21, 2010 | HP Compaq Presario F500 F700 and G6000...
My Compaq Presario F500 running Vist Home Basic will no longer boot the operating system after I completed an advise BIOS update from HPs websit. I receive an error code stating that the system is cor
Hi.
Try this >>>>
Power down your Compaq Presario F500 notebook computer. Remove the unit's internal battery from its housing compartment.
Use a screwdriver to unscrew and remove all of the screws from the bottom panel of your Compaq Presario F500. Use your hands to lift off the bottom panel, revealing the inside of the notebook computer.
Look for the CMOS/BIOS chip: It will be located in the center of your computer's motherboard, which is itself located in the center of the case.
Remove the small battery from its housing compartment on the CMOS/BIOS chip. Then, press and hold the "Power" button on the laptop's case for a few seconds. This will completely discharge all electricity from the device.
Replace the CMOS/BIOS' battery. Place the bottom panel of the notebook computer back on and screw it back into place. Place the Compaq Presario F500's battery back into its housing compartment and press the "Power" button to turn it on. Your CMOS/BIOS will now be completely reset.
Good luck and please let me know how you get on!!!!
Regards.
Jan 29, 2013 | Computers & Internet
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
I have a Compaq Presario F500 When I press the power button all the lights light up for a few seconds then it shuts back off
remove the battery then try to plug the charger directly on your laptop without a battery.. to test if the battery is working properly. if not.. maybe your main board have a problem. just like athe compaq presario of my friend. also mainboard problem.
Jul 10, 2011 | HP Compaq Presario F500 F700 and G6000...
The Compaq f500 don´t start. The power light is on
first take battery and power out
then blow in vents with hair dryer warm air
put battery not power back in
turn on and wrap in towel
leave for 45 minutes
open back up and plug in power done!
i was shocked when this worked
Sep 10, 2010 | HP Compaq Presario F500 F700 and G6000...
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F500 - won't boot up - power and lights etc on, tries to start but cuts out after about a second I have the same problem, this F500 notebook is just getting me nuts and no, it is not...
check the power supply, either the power cord or your power supply in the laptop.
and NATurally..happens aFTER the warranty expires, that sounds about right.
Apr 13, 2009 | Computers & Internet
I need audio drivers for compaq Presario F500 laptop
 helo ser i'm joni rahman . from indonesia  plis whit deriver vga,sound,wireles, driver to all fromPresario 500 laptop
oke thengs ser
Feb 06, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
4,544 people viewed this question
David Payne
David Payne
