Question about Acer Aspire 5100 Notebook
What can i do? my laptop screen wont turn on.? the comp turns on, but the screen wont. it has power/battery. works normal, no virus. slow system. but sometime it works. and sometime the screen doesnt turn on
  • bwhardwood Feb 21, 2009
    turn on computer but screen dont come on. Computer just runs?
  • 49 Answers
- Try using a desktop monitor and check if the issue still persist, If the issue is not happening on the desktop monitor .It maybe the LCD.
- Check If you can download some manuals of your system and try to check if you can follow the instruction on how to reseat lcd cables inside your laptop. If you can do it it will help us isolate the issue.
Posted on Oct 08, 2008
Laptop black screen
You turned on your laptop and horrors upon horrors, the screen is BLACK! You see that the laptop has power but besides that nothing is happening.
I want you to know that there is a very good chance you can get out of this situation quickly and without any cost. This fix works on all brands of laptops:
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen.
After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
or if wont start
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer.
There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer.
Aug 08, 2013 | Computers & Internet
Avira antivirus free download
Have you tried a System Restore to a date before this issue?
May 29, 2013 | Dell Computers & Internet
Mercury leaks in laptops?
Laptops have very little or any mercury in them. There maybe a little mercury in the tiny CCFL lamp in the LCD screen and unless you break this lamp there is no need to worry.
Feb 07, 2013 | Computers & Internet
I turn it on and it makes the sounds of starting, no screen, it ran all night, I could hear that. now it just wont turn on the screen. Have I pushed a button or something wrong.
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 11, 2010 | HP Computers & Internet
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
May 05, 2009 | Dell Latitude D600 Notebook
HP pavilion dv5 notebook PC screen BLACK !! Help
Make sure you don't have any discs on DVD rom or CD rom. if you don't , uplug comp. from outlet, remove the battery, press and hold power button for about a min..reconnect it to electricity and power back on...If it does not work, respond to me.
Apr 13, 2009 | HP Pavilion dv5-1140us Notebook PC
Dell inspiron 6400 system responding very slow on ac adaptor
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Compaq Presario v2000 notebook screen ghosts out and system running slow
for the display you can check by connecting the laptop to the monitor through the vga port
Oct 03, 2008 | HP Compaq Presario V2000 Notebook
Problem During Boot-Up
several things it could be but im going to look at the obvious the battery and cord hook up
laptops when plugged into contstant 120 power the battery is supposed to go into stand by mode and shut battery off so power dont leak into battery
if you have low battery with it plugged into 120 the comp will still think the battery is powering the laptop if battery dead then comp shuts down lack of power
other thing is somehow you caught a virus that reboots comp from dos screen mode
the main thing i always ask is what was the last thing that happened before it did what its doing now
example= was there a power surge pop up screens ect.
May 09, 2008 | Toshiba Satellite A75-S231 Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
