Question about Toshiba 14" LCD Monitor
Toshiba monitor on-off
I have a Toshiba flat-screen monitor form my home computer. (I'm at work now, so I don't have the model # handy.) A few nights ago, I turned the monitor off to save energy. When I turn it back on, the on-off switch flashes blue about every other second, but the monitor does not light up. I tried jiggling the mouse, hitting keys of the keyboard, and -- ultimately -- turning off and restarting the computer. No luck. Any ideas?
CompuGuy44
  • 432 Answers
SOURCE: Laptop monitor blacks out, but when you hit the toggle....
Sounds like you need a new Switch. Oxidation has probably built up in the switch. It can be fixed. Probably shop around for a certified tech who can replace it. The switch is cheap, Labor is starting around $65 - $90. You said you can faintly see the desktop. This is the invertor board inside the LCD assembly that causes this. Again if it needs to be replaced, the invertor is fairly inexpensive, labor isn't. The technician that ckecks out the laptop can determine what it needs. Yea, your right, it is a good laptop and it is worth fixing. Just a heads up, if the tech says you need a new motherboard, he's lying, find another tech.
Posted on Jul 03, 2007
  • 17 Answers
SOURCE: screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Posted on Feb 22, 2009
stabelabel
  • 51 Answers
SOURCE: HELP ME!! LCD SCREEN WONT TURN ON! TOSHIBA SATELLITE A215-S5837
it sounds like a hardware problem. I would say your high voltage board that drives your lcd has blown probably the caps you buy new on-line and replace it. send to factory service to have fixed. get fixed on warranty if you have it.
please let me if I helped
Posted on Mar 21, 2009
Jack_Dawson
  • 287 Answers
SOURCE: turn on wireless switch and laptop turns off and
1. It's a bad memory problem! (Blue Screen)
2. Try to close unneccessary processes / software using Task Manager before switching ON wireless!
3. Now, switch ON wireless.
4. If it don't work, reinstall the wireless driver!
5. Restart ur system.
tell me if it helps...tc! :)
Posted on Jan 04, 2010
BlacMamba
  • 215 Answers
SOURCE: Hello all. I'm in desperate need of some help. ,
Hi,Try doing these,turn the system upside down,the maybe two compartments,unscrew the compartment at the middle locate the RAM Chips two in number,dislodge each one after by pulling the lever at both ends slightly bring them out of the system,now select a slot of your choice and put just one in,power-up the system,if system does not come on,power down,remove RAM put the second one into the Same slot like you did the first,if system does not come on try the second slot.if after all these system still does not come on i will advise you take to qualified service personnel.
Posted on Dec 30, 2010
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Hi the sceen goes black when it is switched on for ten minutes if I switch it off for a few minutes the sceen comes back on. It will then shut off again after a few minutes. Thanks Alan
This is due to the inverter for the backlight, or the backlight itself going bad. You are going to be better off replacing the screen unless you are handy with electronics.
Sep 08, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
The monitor startup and few seconds later it turn
You are going to have to open up the monitor, please read below if you are going to DIY.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 216BW Monitor
Flat screen no longer has power?
Power supply will be the first place to check for bad caps with bulging top/seals, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Report back what you see so we can guide you further.
Feb 10, 2010 | Computers & Internet
Monitor was working fine last night but I think Microsoft did an update last night and i can't get the monitor to display. I get a check signal cable box that floats across the screen.Also do not have the...
Please unplug the monitor cable from the back panle of the cpu and replug it back again ensuring a tight connection.
this should take care of the problem.
Jan 22, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
My laptop toshipa A135 has died. when i push power
In this case you need to check the inverter, defective inverter will cause the following symptoms:
No Display
dim screen
Screen Flash on and Off between 1/2 to a few seconds
Actually you need to replace the inverter buy a new inverter which is compatible to the old one. Installing the inverter is easy, it does not require any technical skills. In fact, it is a lot easier then changing the I/O Card in your PC System because there is no driver ( Software) Involve.
Tools:
Philips screw driver
Small Flat screwdriver
Preparation:
Make sure your have enough space on your desk and it must be clean.
Disconnect AC Adapter and Remove Battery from Laptop Computer.
Procedures:
This procedure is based on Toshiba Satellite A105-S4284 (with 15.4 inch Screen)
Removing the front bezel on Laptop screens is easy. Usually, these screws are covered by small rubber pad; so, all you need to do is remove these rubber pad and screws. To do this procedure you can find some instructions as shown on the next few photos to the link that i can provide below.
http://www.lcdparts.net/howto/instruction/IInverterDetail.aspx?Model=A105-S4284
Good luck, thanks for using fixya
Regards
nicole
Oct 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Flat screen monitor functioning strangely
Sounds like there maybe bad caps on the power board in the LCD. Try a different monitor on your computer and if the known working monitor comes on with the computer and behaves properly then you know its a problem with your original monitor. If the known working monitor acts strange as well then you know its a problem with the video card. Let me know what happens.
Jun 11, 2009 | E-Machines eMachines Desktop PC
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Computers & Internet Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
