Question about IT Works DVC303 Digital Camera
Memory card i got a it works d v v 561 camera.when i insert the memory card it goes off,,...if i leave the memory card inside i cant turn it on....pls help me
Format error when trying to use memory card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 22, 2010 | Norcent Technologies XIAS DCS-860 Digital...
    Formatting code for SGH E-840 forgot password to use application phone is working but cant view images and cant play music. pls help wht to do
    hello Sir
    #1
    Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
    #2
    #3
    #4
    #5
    #6
    Dec 22, 2009 | Samsung SGH-E840 Smartphone
    My easyshare model m1093is comes on then goes off batteries are good
    Remove the memory card and the battery
    Clean the metal contacts on the battery using a clean cloth
    Use the camera w/o the memory card
    Pls test with an alt. batt.
    If you do not have access to a dif. battery.
    Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
    Contact KODAK:
    http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
    Oct 12, 2009 | Kodak Cameras
    My kodak digital camera wont stay on!
    Your problem could be the result of corrosion on the battery terminals inside the camera. Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, clean both ends of each battery, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
    http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
    Aug 16, 2009 | Kodak EasyShare CX7530 Digital Camera
    What does no card mean? Thank you.
    "No card" means that either
    1. You have not inserted a memory card
    2. The memory card is not formatted, or
    3. The memory card is damaged and therefore can't be read by the camera.
    How to insert the memory card:
    1. Open the camera’s battery door by sliding it downwards.
    2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
    3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
    Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
    Before you can use the card, it has to be formatted:
    1. Insert the memory card into your camera as described above.
    2. Turn the camera on by pressing the power button.
    3. Use the multi-select button to select the "SET" option.
    4. Press the right arrow button to set "System" then press down key to select "Format".
    5. The default option is ‘Format’. Select this option by pressing the OK button.
    6. Select "Yes" to format the card.
    If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
    Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
    MEMORY CARD SLOT FOR N70 CAN'T READ / CANT TRACE MY MEMORY CARD
    your card may need to be formatted for use in the phone. The phone supports FAT32 file system go to Menu - Tools/Setting - MemoryCard - Options - Format Mem Card and click YES
    WARNING: Back up you card on your computer first because formatting you will lose your contents
    Jun 19, 2009 | Nokia N70 Cellular Phone
    Pls my sony memory card shows me formatting error
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    Jan 11, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
    N 73 screen
    remove the memory card and try it work's properly. after u just insert the memory card i likely to be working.. better u need to format the memory card..
    Sep 06, 2008 | Nokia 6230i Cellular Phone
    Camera wont work when memory card is inserted
    I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
    Mar 06, 2007 | HP Photosmart M417 Digital Camera
    Insert memory card, LCD turns lank
    Hello Rach326, try with a new SD card. If it does not help contact the nearest authorized dealer/service. Best regards, Arpad
    Jan 12, 2007 | SeaLife Reefmaster DC310 Digital Camera
    Cameras Logo
    27 people viewed this question
    Top IT Works Cameras Experts
    Are you an IT Works Camera Expert? Answer questions, earn points and help others
