Question about Imperial IFS40 Deep Fryer
GAS VALVE TIMING OUT
I HAVE A Imperial IFS40 Deep Fryer THAT I HAVE REPLACED THE
GAS VALVE,T'STAT,AND HI-LIMIT SWITCH IN. MY PROBLEM IS THAT YOU CAN BE COOKING AWAY, AND ALL OF A SUDDEN THE UNIT SHUTS DOWN (EVEN KILLING THE PILOT LIGHT). WHEN THIS HAPPENS YOU CANT RELITE THE PILOT FOR A FEW MINUTES. THE PARTS REPLACED WERE NEW FACTORY IMPERIAL PARTS. I AM AT A LOSS TO FIGURE THIS PROBLEM OUT.
ANY HELP APPRECIATED.
  • 3 Answers
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Posted on Oct 29, 2008
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Imperial propane fryer won't stay lit.
check the high limit it tripping out
May 22, 2009 | Imperial IFS40 Deep Fryer
Fryer will only go to 250 degrees
Need to calibrate the thermostate,or replace it
Mar 12, 2009 | Imperial IFS40 Deep Fryer
Imperial deep fryer IFS40 pilot lights, turn on gas valve main burners come on run for awhile then everything shuts down main and pilot. You can disconnect the thermostat and the same thing happens, main...
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Feb 18, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Fryer pilot lit but main burner does not come on
IT IS A GAS PRESSURE PROBLEM CHECK TO SEE IF THERE IS A GAS REGULATOR IN LINE WITH THE GAS PIPE TO THE FRYER IF SO ADJUST REGULATOR TAKE TOP ALUMINUM SCREW OF YOU WILL SEE WHITE PLASTIC SCREW TURN WHITE SCREWW TO THE RIGHT ALL THE WAY IF SAME PROBLEM OR NO REGULATOR RESTICTION IN GAS LINE
Nov 10, 2008 | Imperial IFS40 Deep Fryer
Looking for a thermostat unit for the Imperial IFS-40 serie : 05159306 what's the part number??
If you have a manual thermostat,(inside door, knob) your part is
#1175 OPERATING THERMOSTAT (HERMETICALLY SEALED REED SWITCH)
If you need the Hi-limit t-stat --
#1177 HI-LIMIT SWITCH
If you have digital control, with digital temperature control, the unit uses a probe.
#1094 FRYER CONTROLLER TEMPERATURE PROBE
Good luck, Mike
Jun 06, 2008 | Imperial IFS40 Deep Fryer
Deep fryer
Make the "tap" is to the thermostat, and not the gas valve. If it is the t-stat, try cycling the knob back and forth, low to high several times. This may free up the contacts in the t-stat. But in general, if tapping "fixes" it, you need a new one.
Good luck - Mike
Apr 29, 2008 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
387 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
