Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
THE POWER WHEN OUT FOR A MINUTE AND WHEN I WENT TO USE THE OVEN IT WOULD NOT WORK. NITHER THE BAKE OR BROIL ELEMENTS INSIDE THE OVEN WORK, I CAN SET THE OVEN TO A TEMP AND I CAN HEAR IT CLICK BUT DOES NOT HEAT UP AT ALL, I CAN HOLD ON TO THE BURNERS. THE CLOCK AND ALL FOUR OF THE TOP BURNERS WORK FINE. I'VE CHECKED THE POWER SUPPLY AT THE BACK OF THE OVEN WHERE THE WIRES CONNECT TO THE BURNERS AND I SHOW 115 VOLTS AT EACH SIDE. IS IT POSSIBLY THAT BOTH BAKE AND BROIL BURNERS WENT OUT AT THE SAME TIME?
  • rockysbabe Jan 19, 2009
    My top burners work but the oven does not. When I turn on the oven the light indicating the oven is on does not light up. When I pushed the clock button all the lights flashes. I can not set my oven clock, the timer, or the oven temperature.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Posted on Oct 09, 2008
Oven gets warm but not hot?
This could be a thermostat issue or a burner issue. Most ovens have a top and bottom burner, if one of them is not working, the oven may not reach or stay at the right temperature. You should be able to get a replacement at home stores that sell appliances or order one online. They are fairly easy to replace. You may have to remove a couple of screws but otherwise they pop out and pop in. You can test the burners by turning the oven on bake and a few minutes later open the oven to see if the bottom burner is red, if not it may be burnt out. You can set the oven to broil and after a few minutes, look at the top burner, if it's not red it's likely burnt out. If both burners seem to be working, it is likely a thermostat issue. I haven't replaced one of them before, but you should be able to find instructions on youtube to determine if it is something you are comfortable replacing on your on.
Aug 11, 2017 | Ovens
Oven and elements not working,
the oven and burner relay that supplies power to the bake/broil/top surface units is bad or the signal to latch this relay is missing from the control panel
Jun 03, 2012 | Moffat Ovens
Bake pre heat isn't working broil and top burners
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 07, 2011 | GE Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
326 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
