Question about Lands Phones
I have a 5.8 GHz AT&T cordless phone and telephone answering system. The base unit functions properly but the remote phone doesn't have a dial tone.
The mute button is on and we don't know how to turn it off. It is blocking the main line.
Posted on Oct 08, 2008
Just got a new kx-tg7643m system. all handsets and base show message. new voice mail. there are no messages in the answering machine. ? how to erase the message. thanks.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 01, 2012 | Panasonic Kx-tg7643m Cordless Phone - 1.90...
Can't listen to my voicmail
Click on a left side link of download manuels. ------------ 40000 series DS4122-4 ------------ 50000 series cs5121-4 ------------ i6785 English Not sure what series you have, but take a look at these manuels. found here :http://www.vtechphones.com/vtechui/support/manual_list.cfm#214 if not anyof these listed- there are many others to view and I know you'll find right instructions here!! Let me know if this helped.--Stevie ----------------------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID ------------------------------- 5.8 GHz digital Four Handset Cordless Phone System with Digital Answering System and Caller ID --------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID i6785 - Spanish 5.8 GHz Digital four handset telephone system with digital answering system english i6786 5.8 GHz digital four handset cordless phone system with caller ID and digital answering device i6786 - Spanish 5.8 GHz digital four handset cordless phone system with caller ID & digital answering system
Feb 14, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
No dial tone
Try disconnecting all units plugged into telephone service. ie. phones, computers, fax machine, sat. rec etc. Then take a known working wired phone to check for dial tone in each of the jacks. Plugging in each unit one at a time, you should be able to find your bad equipment. Disconnect bad equipment and reconnect remaining.
Apr 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
GE 2.4 GHz cordless telephone problem
Hi there, maybe I can help;
Is the phone base plugged into an switched outlet and is the switch off?
Let me know if I helped
Jan 06, 2009 | GE 21008GE2 Dual-Handset Cordless...
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
Phone not working properly
my answering machine keeps syaing that you can not leave a message at this time but i set it up can you help me
Mar 30, 2008 | GE 27851 Cordless Phone
GE 5.8 ghz cordless phone
Get another telephone and connect the telephone cord from your cordless phone to it. If it works, then you know the problem is with your GE cordless phone. If it doesn't, try replacing the telephone cord. If still no good, call your telephone company.
Nov 05, 2007 | Uniden Cordless Phone
Cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
May 09, 2007 | GE 25831GE3 Cordless Phone
HUM
DSL line. Possible that filters are not plugged in. When DSL service is being used on your line, filters must be installed at every jack that is in use. The DSL signal can cause static/noise, squealing (similar to fax tones) and other issues on your line. (ex. Caller ID problems). In order to avoid having this issue, the service provider gives DSL filters to all customers when they sign up for service. These microfilters must be used because they allow your phones to work properly by blocking the high frequency DSL signals from being transmitted through the telephones. DSL filters should be plugged into EVERY phone jack that has a phone. If you are not using the filters provided by the telephone company, this will cause static/noise and possibly Caller ID issues on your phones that are plugged into jacks without filters. Please contact your service provider for filter information and proper installation. Interference: Other 2.4 GHz products. Other products that use the 2.4 GHz band can interfere with the use of this phone. Items include: Radio towers, pager towers, cell phones, other 2.4GHz cordless phones and 2.4 GHz intercoms or monitors. If any of these items are in the area, they can interfere with the performance of this phone; try relocating the phone. Other 5.8 GHz products. Other products that use the 5.8 GHz band such as home networking (wireless modems) other 5.8 GHz cordless products (phones etc.) can interfere with the use of this phone. Try relocating the phone. Interference from microwave. Microwaves work on the same frequencies as the 2.4 GHz phones. If the unit is on when the microwave is running, it is normal to experience static at that time. Do not plug this phone in the same outlet or near the microwave. Environmental. Normal radio operation. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. Try channing channels. Surge protector or modem. Unplug modem or surge protector that is connected to the unit. Building structure limits range. Relocate telephone base near window when using telephone outside. Base unit located in basement or other low area. Relocate telephone base to higher location. The unit will get better reception if it is not located in a low area. Video displays, television sets and personal computers may cause interference. Video displays, television sets and personal computers can cause interference on this phone. Please relocate the phone to an AC outlet were there is no major appliance plugged in. If the base is near any of the above mentioned, locate the base to another room. Possible telephone line/service problem. Try using your equipment at a different location (i.e. friend or neighbors). If the unit functions properly in the new location, contact your local telephone company for assistance; additional charges to be incurred by customer may apply.
Feb 11, 2006 | Vtech VT 9152 Cordless Phone (VT-9152)
Lands Phones Logo
111 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
