Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Bluetooth I've been trying to send files via bluetooth on my samgsung tocco and it just won't work! Everything is switched on and activated, i can recieve files and i can search for devices i just don't know how to connect to them! I've tried to click on the icon but it just gets a blue 'halo' and then does nothing!!! Any ideas on whats wrong? I shoudl add my friend who also has a tocco has the same problem - are we both just being really thick???
  • lulu79 Oct 08, 2008
    Realised i was being a bit thick! All i needed to do was move the icon towards the bluetooth picture in the centre of the screen and it connects.
    Doh!
  • 29 Answers
Click on the file u want to send, then options, send via blue tooth, click ok, then it will search for devices, click on the device u want to send it to, it may ask u for a pin, (make up a number, i always use 123) click send, then it will ask the other person who ur sending it to for the pin, they type in 123 (or wat ever ur pin u used) then it will transfer x
Posted on May 07, 2009
  • Kay Tapsell
    Kay Tapsell May 11, 2009
    i was gonna say that!! thought u had already tried that!! lol it ses how to do it in the booklet on the bluetooth section!!!
How to send music in cellular phones via bluetooth
Hi.Make sure that the sets are currently active the bluetooth or not....and in the bluetooth setting Phone's visibility should be "Shown to All".Open the music file list and drag the key to the particular files you want to send after this press option and select Send Via bluetooth.Than you will be asked for selecting device "just press New Device".This are the procedures.Good luck
Oct 06, 2011 | Nokia 6300 Cell Phone
Unable to perform bluetooth at nokia 7610 mobile
To activate BT, try the following:
1 Press Menu, press Connectivity, and then press Bluetooth. 2 (Optional:) Enter a custom name for your phone, and then press OK. 3 Set Bluetooth to On. 4 Set My phone's visibility to Shown to all. 5 Press Exit to return to the previous screen.
When sending, choose a file you'd like to send, click options, and then send via bluetooth.
Jan 12, 2011 | Nokia 7610
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you
select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed
My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running
on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery
application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon,
the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already
exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the
devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new
search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to
be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and
the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a
passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device
to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the
device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via
Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the
devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for
both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is
shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the
message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
I am not able to connect my bluetooth device with others n not able to share information with other via bluetooth
Hello
First ensure that your bluetooth is on and visible to everyone
When you want to send a file and scroll to "Send via Bluetooth" on your phone, your device list may come up empty. Sometimes this can be resolved by physically moving the devices closer together. The maximum distance between devices is 30 feet -- less if there is an obstacle blocking the signal.
check to see if the receiving device expects a security code before receiving transmissions. Some phones have security restrictions to prevent hacks.
Most Bluetooth-equipped devices come with a factory-set name. Change your device settings so that all your electronics have unique monikers. There are still some compatibility issues among Bluetooth devices, too. If you can send a file from your phone to your computer, odds are everything is working properly, but you have compatibility issues with the receiving device. Check the manufacturer's website for software updates for your phone, or visit a service center. But be careful: New phone software that updates the operating system can erase all your phone information.
Oct 02, 2010 | Ericsson Cell Phones
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
Aug 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I cant send music files to it via bluetooth it keeps telling me to delete memory and now ive deleted everything and it still wont let me send music files via bluetooth. I have a nokia navigator 6110
make sure that all of the files that you have sent before via bleutooth was move on your memory card.take a lokk at your phone memory on how much is the free space.because once you transfer file via bluetooth it uses your phone memory. check your inbox outbox and myfolders.delete or move the files that is in there.then try to send via bluetooth again.hope I explained it well.
Apr 15, 2010 | Nokia 6110 Navigator Cell Phone
How do i send pictures via bluetooth between a blackberry and non blackberry phone
just activate bluetooth on both phones then go to file u want to send via bluetooth, click on options then send viz bluetooth, click on search for new devices, select device name for phone u want to send file to then send.
Oct 05, 2009 | RIM BlackBerry Curve 8520 Smartphone
Not able to send anythin via bluetooth....!!!
I don't know whether its exactly the solution or not, but I had a similar problem transferring some mp3 files to any cell via bluetooth from my nokia 7210, I tried all combinations of bluetooth settings, but the same message kept appearing-"Sending failed", finally what I did was "Changing the name of the mp3 files" as all those I wanted to send had a bigger name, I cut the name short and there it worked. So, may be in any such case it's advisable to just try this out, it might just work.
Jul 17, 2009 | Sony Ericsson K790i Cellular Phone
Can i save files sent through bluetooth strait to my memory card on the lg ks360
o send a file via Bluetooth:From the Start-up screen select the Main Menu icon
Go to Multi-media (Figure 1)
Select My Stuff (Figure 2)
Go the images/sounds/videos/documents and select the file you wish to send
Select the Menu icon at the bottom left of the screen
Select Send Via (Figure 3)
Then choose Bluetooth (Figure 4)
You will then be presented with a list of devices in your area. (Figure 5)
If you do not see the device you wish to send your file to ensure it’s has Bluetooth switched on and select New
Your handset with then search for all Bluetooth devices in your area (Figure 6)
Select your device and your handset will send the file (Figure 7)
The Bluetooth device you are sending your file to must accept the file (Figure 8)
To receive files via Bluetooth ensure you have Bluetooth switched on – only accept files from devices you recognise.
You will receive a message stating the file name with the option to accept or reject the file
To receive select Accept (Figure 9)
The file will then be transferred to your handset (Figure 10)
It will then be saved in your images folder
Oct 18, 2008 | LG Cell Phones
Sending data /images / mp3 via bluetooth to other mobiles
it will not show u sending via bluetooth but it sends as beaming the file
Dec 12, 2007 | i-mate JAQ Pocket PC
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
66 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
