Question about Zebra Stripe S600 Thermal Label Printer
Zebra s600 When the printer is powered up both the Printer/Ribbon and the Print Head lights are lit. These cannot be cleared.
Downloaded firmware
Posted on Oct 10, 2008
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
Can a Zebra S600 printer print labels without using a ribbon?
Yes it can but you have to use DIRECT THERMAL MATERIAL. That eliminates the need for a ribbon but what most people don't realize is that a ribbon is almost like "Oil" in your car. Direct Thermal material is more abrasive and will wear out your printhead much faster. Now if you don't print lots of labels that may not be a big deal but if you print 500+ labels a day then thermal transfer may be a better choice in the long run. Printheads are one of the most expensive components of these printers.
Regards,
mikeo@acebarcode.com
Feb 24, 2011 | Zebra Stripe S600 Thermal Label Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
I am having problems with our Zebra Stripe S600 if I ask it to print 500 labels it will only print 3 then I have to line the label and ribbon back up, any advise would be gratefull
Recalibrate the printer, it seems it might have lost it's calibration. Chekc and clean all sensors in the paperpath with Isopropyl Alcohol.
Jan 21, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 will not do anything???
Emma, I can assist but this is slightly technical. The issue more than likely is the print head sensor flag is out of position. If you have the print head all the way down & purple toggle in the locked position but the print head light still flashed then more than likely it is the flag that came loose. To correct it means you have to remove the left side cover where the logic board is. Make sure to remove power cord & all communication cables & connectors prior to cover removal for your safety. After the cover is removed you will see the logic board. On the upper right corner area will be a SCREW with a black "L" shaped piece of plastic, this is the flag. At this point make sure the print head is down & locked. Place the flag in the horizontal position, which should be between the sensor positions, While holding retighten the screw. Once tight open & close the print head to see the flag move up & down between the sensors. Place the cover back on but put 1 screw in only so you can test. If all works put the rest of the screws in & continue to work. If not then update this & I will get back with you.
Feb 09, 2009 | Zebra Stripe S600 Thermal Label Printer
Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Aug 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra s600
The factory default setting for the S600 is thermal transfer (ribbon). depending on your OS there is a command that can be echoed to the printer to change the setting to direct transfer (non ribbon). It sounds like your printer thinks is should use a ribbon and in fact you are not using a ribbon. Here is the procedure I use to get the ribbon motor to turn on:
1. start with the printer turned off.
2. open the printhead, retract the ribbon completely onto the supply spool. leave the printhead open.
3. Press and hold the top three buttons (PAUSE, FEED and CANCEL) while turning on the printer. When the botom couple lights turn off release the buttons.
4. When you are left with the power light on and the printhead light blinking reinstall the ribbon and close the printhead.
The printer will autoclaibrate and run a sensor test.
Once complete the take up motor should have turned on and you should be able to use thermal transfer labels and a ribbon.
Nov 21, 2007 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
306 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
lancer284
Level 1 Expert
kenneth njonjo
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
