Question about Sharp Office Equipment & Supplies
How do I connect sharp printer to network? And also I do not see USB port on the machine
  • 49 Answers
- Check If the modem or router support printer network connection. If yes
- Check If the printer has an option to install a network connection sharing.If yes
- Install the driver for the network printer sharing and connect the printer to any modem or router.
-You can also check the printer manual to get some overview of your concern
Posted on Oct 08, 2008
Let me know how can I connect canon c3100 to my PC so that I can use it as a printer.
U can connect through a network or even as standalone printer through usb port.In network connect the machine to the network through rj 45 cable and then load the driver in the server and access it from there .
Through usb simply run the driver when it asks to connect the machine connect the usb lead and rest it will take care of.
May 23, 2011 | Canon imageRunner C3100 Copier
Can the Sharp al1642cs work with just usb connection?
I've been using my AL1642CS connected by USB to my Windows XP Pro desktop for about a year now - very reliably - both for printing and for scanning. I love the duplex print feature, so much easier on the trees!
I've also printed to it through the USB port on my network router - but then I can't use it for scanning since Microsoft never enabled network scanning - only network printing!
Dec 06, 2010 | Sharp AL-1642CS Copier
I want to connect my sharp ar 507 to the USB port of the pc to improve the data tranmation in aprinting job.really i used adapter from pc USB to the parallel port in the machine but doesnt work, althogh...
Test your cable elsewhere and see if it works, if okay, use another port in your computer.That should solve it otherwise replace your printer card in your printer.
Nov 17, 2009 | Sharp AR-507 Copier
Sharp am
Well you have to way to connect to this machine, either by usb cable or network cable, if it is usb cable, just put the cd and regular installion, but if it is network card, you have to asign an ip address for the machine, so the computer can connect to that address and then load the driver as network device.
Thanks for using Fixya
Oct 07, 2009 | Sharp AM-900 All-In-One Laser Printer
Can't install sharp ar 5316e printer
You can install it from the cd that came with the copier and then share the printer on the network and assign it a name.It will appear on the list of available printers.
Jul 31, 2009 | Sharp AR-5316 Advanced Digital Imager...
Can an AR-337 printer/copier be attached to a network and, if so, what hw/sw is required?
Yes it can, you need the print server hardware, depending on the printer port your printer used, is it a parallel port or usb connection. If it used a parallel port you can use D-LINK DP 301+ to connect it to your network.
May 28, 2009 | Sharp Office Equipment & Supplies
XP machine can't print from Vista machine
sharp drivers usally requirt port software 1p2p type set up mot as easy as ho ot lemark should sonsult local service in your area
Feb 24, 2009 | Sharp AR-M237 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR 5320 USB Printer port does not working
The usb cannot be switched off in either service of customer modes. have you tried using the parrallel port? Maybe it is a computer issue, wrong drivers perhaps, try a different usb port on your machine
cheers
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
145 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
