I have a Canon Copier Model PC720. The warning light which looks like paper going through the rollers cam on. I inserted a new cartridge (ink) and the light is still on and the copier will not operate. Bruce M. Howden
    Guru:
  • 1,894 Answers
Does it show any error message?
if so please tell us the error code
Posted on Oct 08, 2008
  • dewan nafees ahmed Oct 08, 2008
    if you are sure that the warning was for the new ink.
    then plug off the unit from wall power for one hour and then reinsert the unit and try to start.
    see if the error still persists
    thank you
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
Paper jam tightly fan-folded above ink cartridge
Most likely a broken gear in the fuser (heater) assy. - will need to be replaced by a tech.
Feb 25, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
Message says; Paper jam. There is no paper in it. Tried turning off and back on, resetting. Nothing, same message. Any ideas? Thanks, Niki
Open the back door and look in the middle of the back cover, there's a black plastic sensor lever that must move up and down freely as the paper passes. That lever gets sticky and needs to be cleaned with alcohol so it can move freely again. You may need to remove the back cover with 2 phillips screws to gain access.
Please rate my response!!
Jan 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Lines across paper when photocopying on a canon #D-320
take it back to the store or call the canon customer service
Jan 06, 2009 | Canon imageCLASS D320 Digital Copier
The ink cartridge in my Canon - PCII is stuck.
put off your copier. kindly look at the side where your paper exit , u see an opener, this will open the copier. then draw the cartridge
Dec 05, 2008 | Canon PC-940 Black and White Copier
Printing 1 1/2" down right side of paper
You have a defective toner cartridge, drum should be clean when you looked at it, the blade is failing. Is the cartridge remanufactured (or compatible)? Although they usually work well (depending on the supplier) there are sometimes defects
Nov 25, 2008 | Canon PC-980 Color Copier
Hello I have a canon lbp2900 which has been functioning well. When I try to print i get a message asking me to insert a toner cartridge, however there is a toner cartridge in the machine and I am sure that...
I just posted the similar problem recently. After talking to canon printer service tech, this is what solved my problem:
1. open the top cover and remove the cartridge
2. Inside the printer, these is black roller (with sponge&soft material). Press this gently couple of times
3. below this roller, there is a gray roller. press this roller upward couple to times gently
4. insert the cartridge and try to get print out
hope that helps.
May 12, 2008 | Canon Office Equipment & Supplies
Canon Pc720 Copier Paper Jam
The problem with the paper jam (but not feeding) is that a small
piece of plastic that holds one end of a spring the causes the feed
gears to push against the powered gear on the back side of the toner
cartridge breaks off. So the unit does not feed (no pickup rollers
etc) and it thinks there is a paper jam (no moving paper). Orienting
the front as the side you work at, the back being the back, the
feed being the side the paper goes into and the output being the
side the finished copy comes out, open the unit. Looking into it
from the output side almost to the input on the bottom notice the
small hairlike things sticking up. Move to the left (back of the
machine) and see a few white gears all hooked into this gray metal
housing that moves up and down about 1/2 inch (It pivots). At the
top input side of this metal you will see a part of the metal that
stick up and has a small slot in it. the spring used to hook onto
this and the other end hooked to a small piece of plastic down and
more to the input side a bit, onto the upper input side of the white
plastic part that houses a shaft to a roller (fat little spring
about 1 inch long). the plastic part breaks off and you usually
can't see that a part was even there. The spring will still be in
the area. If you are handy, you can figure out how to fix it. I got
a longer spring (same strength) bent the metal toward the back 1/4"
and ran the new spring from there to a 1/16 hole I drilled in the
plastic side next to the circuit board (down low and back). I shaped
the end of the spring (where I drilled)to keep it more inside and
not hit anything. Works fine.
Steven
Oct 19, 2007 | Office Equipment & Supplies
89 people viewed this question
k24674
jasbo
jasbo
