Question about Sony RDR-VX525 DVD Recorder/VCR
Remote is stuck in dvd 3 mode
  • 1 more comment
  • mangotango Oct 21, 2008
    I have the same problem, but it's stuck in DVD-2 mode. Have tried both solutions listed here and remote stays stuck in DVD-2 mode, leaving my recorder inoperable. Help! Can't reset to default, DVD-3. Thanks!
  • Anonymous Jan 11, 2009
    SONY DVD RECIRDER - RDR VX 511 - LOCKED IN "CHILCLOCK" POSITION AND WILL NOT RESPOND TO ANY INSTRUCTIONC. help!
  • tonymarco134 Feb 10, 2009
    what if you don't have a remote all you have is a cable tv remote
  1. On your remote, push and hold "Enter"
  2. At the same time, push and hold "2"
  3. Keep them down for about 5 seconds
  4. Your remote should now work with the unit
  5. You can go to the set up menu and change the unit back to DVD3 if you wish, but you'll then need to repeat these steps using the "Enter" and "3" buttons
Posted on Dec 16, 2008
Thank you, MoJo! I had done that a hundred times before already and here is what made the difference....I had to change the DVD input setting on the *remote control* (lower right hand corner) to, in my case, DVD-2. It was set on the previous DVD-3. Once I clicked it over to DVD-2 (my remote was stuck on DVD-2) and did the Enter and 2 hold like you said, it worked!!! Yipppppeeeeeeeeeeeeee!!!!!!!!
Thank you Mojo!!!!! Very clear instructions. 1, 2, 3, 4, 5...
To the person whose machine is stuck on DVD-3, do what MoJo said to do for you (Enter+3), but first make sure your *remote* (lower right hand corner, under the pullback) is set on DVD-3. It should be the setting all the way to the right. This will work, trust.
Thank you Mojo!!! After MONTHS, my machine is back in working order! Merry Christmas!!! :D :D :D :D
  • mangotango Dec 16, 2008
    I gave Mojo a 4 star rating and it's not showing up. Thank you MoJo!!!
  • mangotango Dec 17, 2008
3 Suggested Answers
SOURCE: Remote is Stuck in DVD 1 mode
solution to the problem is as follow:
1. press down the "ENTER" buttom and then press the "1" number buttom for about 5 seconds
2. press down the "ENTER" buttom and the "3" number for aboput 5 seconds.
This should reset the recorder to the DVD3 mode
Good luck.
Posted on Oct 05, 2008
I had this same problem: Recorder displaying "DVD 1" whenever I pressed any button on the remote. Called Sony Tech Support and this is what they told me to do: 1) Turn the unit on; 2) Press the Enter and the 1 keys on the remote at the same time for 5 seconds. (This I was told was to set the remote to DVD 1); 3) Press the System Menu key on the remote to bring up this menu up on the TV screen. (This takes a few seconds, so be patient.); 4) Access the Setup Page on the menu and set your unit via this way to DVD 3 if you want. (The Tech actually said I could leave it at DVD 1 if I wanted. I set mine back to DVD 3 - default.) I then performed auto-Set-up on my unit, and everything was back to normal. Hope this helps, otherwise I would recommend calling Sony Tech Support.
Posted on Aug 22, 2009
Display says it is stuck on dvd 2 cannot program the dvd recorder to record
DVD recorder stuck on DVD 2 mode that means you can no longer operate it with its remote, right?
Now you need to change remote mode to DVD 2 so recorder can receive its signals.
Slide down lower cover of remote and set Command Mode switch to DVD 2 position, now your recorder will get remote signals and you can operate it properly.
Thanks.
Jan 18, 2011 | Sony RDR-VX521 DVD Recorder/VCR
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
Device locked up
Check dvd recorder remote that has 3 dvd mode switch DVD-1, 2 and 3
set it to DVD-1 and remote will work with dvd recorder.
May 17, 2009 | Sony RDR-VX525 DVD Recorder/VCR
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
I had this same problem (DVD1). Resolved as follows: With DVD player on, pointed remote at DVD player, pressed and held the 1 key and then pressed and held the enter key (both at same time) until I saw the DVD1 on the DVD player display disappear. Now everything works.
Jun 23, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
Nov 10, 2007 | Mintek DTV-323-D TV
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Sony RDR-VX525 DVD Recorder/VCR Logo
441 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
