Question about Evolis Dualys Thermal Card Printer
Pebble 4 miss ribon setup from time to time
We are issuing cards with a Pebble 4 thought TCP/IP conection using a windows program. We are using YMCKO ribbons. We are printing color photo and black text. From time to time, the printer does not print the photo and prints just the text. The we go to the driver configuration and, spite of the ribbon is right, we set a different ribbon type and the set the YMCKO ribbon back again, and the printer prints again properly until next error. We have updated the firmware (we already had the last windows driver version) but the problem persist. Any Idea?
    Novelist:
    Scholar:
  • 66 Answers
Sounds like a failed/failing ribbon sensor. Each color ribbon has an embedded RFID tag. The PC/driver requests the ribbon tag info from the printer, and sets the driver according to the reply (R3011-YMCKO, for example). The mono-chrome/black R2011 and R2211 ribbons don't have RFID tags. If the PC/driver requests the ribbon tag info, and gets a response of "none found", then the driver will be set for "K" ribbon.
This can also be a fault due to spotty communications with the PC - bad USB cord; USB port; printer logic board issues; etc. Try a different USB cord, port & a different PC to see if the problem will resolve. If not, then it seems the problem is with the printer itself.
Posted on Aug 02, 2017
SOURCE: evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Posted on Aug 07, 2008
SOURCE: have a Pebble 4 card printer and the ribbon breaks after each card is printed.
the card are not being fed when printing a test card...
Posted on Dec 11, 2009
  • 54 Answers
SOURCE: My Evolis Pebble 3 ink ribbon breaks after I print
First clean Rollers and print head . Check if you have increased luminosity and contrast too much in printer Graphic properties. If this doesn't solves your problem increase x offset little bit using Px;+ command in Dialog with printer
Posted on Apr 13, 2011
  • 54 Answers
SOURCE: My ink ribbon breaks after
Clean all transport rollers . check for X offset by giving Rx command in Properties/Tools/dialoge with printers. Increase offset little bit using Px command
Posted on Apr 27, 2011
fxurikfx
  • 20 Answers
This is a very common problem within all ID Card Printers and might have multiple causes. Most common are sharp edges at the end of the card, or a high contrast/intensity image thats being printed.
Check the cards for sharp edges, if edges are very sharp and beveled up, discard the cards immediately as they can also damage your printhead.
Lower the quality and/or contrast within the printers divers/graphic menu.
-- The Pros at www.DiscountIDStore.com
Posted on Feb 10, 2012
Hi I got Evolis Pebble 4 and I have problem with printing the ribbon light is always ON and it does not print with YMCKO, but when I change to black ribbon K it prints. What is the problem.
It sounds like your ribbon setting in the printer-driver is set to the R2011 (or R2211) K ribbon. It should be set to R3011 for the full-color YMCKO ribbon. Check by locating the printer in the Windows Devices & Printers view (Win7: Start Button => Devices and Printers; WinXP: Start Button => Printers and Faxes). Locate your Pebble printer; right-click; select "Printing Preferences". Check your ribbon setting here and match to the ribbon that is loaded. NOTE that you can only make changes to this driver setting if you have Windows Admin rights with your Windows log-in ID. If you don't, have your systems administrator assist you with this by logging in with their ID.
May 04, 2015 | Evolis PEBBLE 4 Led Card Printer
Printing...
a) You have a YMCKOK ribbon instead of the YMCKO that you should have due to driver settings(check)
b) You set your driver for K ribbon and you have a YMCKOK or YMCKO ribbon
Nov 13, 2013 | Datacard SP35 Printer
Evolis Pebble 4 with a gold monochrome ribbon. Printing on pre printed blank cards. The print is not complete, almost as if there is not enough pressure on the card as it is printed. All the letters are...
Make sure you have selected gold ribbon in printer graphic properties.
Also you can try changing luminosity and treatment options in graphics under Advanced setting.
Check for print on a white card also as problem may be due to card surface also .
You should cklean print head also at once.
Oct 04, 2010 | Evolis PEBBLE 4 Led Card Printer
My zebra card printer p330 i donbt recognized the colour ribbo YCMK, only detect the mono ribbon
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.
Sep 25, 2010 | Zebra P330i Thermal Card Printer
I have problem with my Evolis Peb3le. For a long time (+- 3 years) ago, i use ribbon with S/N: RP011IPS, and it's running good. But, now, i can't get that ribbon with S/N: RP011IPS, YMCKO, i just only...
Just check for the ribbon type setting in driver . It may be required to be corrected . Also try downloading new firmware from Evolis site for Pebble3.
Sep 19, 2010 | Evolis Pebble Color Card Printer
My Evolis Pebble 3 ink ribbon breaks after I print 2 cards.
Aug 04, 2010 | Evolis Pebble Color Card Printer
Fading image...
1.Check for proper driver on evolis site.
2.Check whether both side printing is selected in driver
3.Check for Varnish sensitivity setting in Graphics setting it should be default.
4.Read the ribbon type with Rr command.
Feb 23, 2010 | Evolis Pebble 3 ID Card Printer Package...
Printing Problem
Use color ribbon and set ribbon type in properties
Feb 17, 2010 | Evolis Pebble Color Card Printer
Evolis pebble 3 ribbon problem
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
Evolis Dualys Thermal Card Printer Logo
52 people viewed this question
Top Evolis Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
