Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Copying I have a Konica Minolta C250. When i try making a copy, a grey film cover the printed page. Is there a security setting i need to remove?
  • lawrence29 Oct 10, 2008
    Yes, but how do you remove the watermark or copy protection?
  • 167 Answers
In the driver there are "copy protect" and "Watermark" options.
See if these are on.
Posted on Oct 09, 2008
Blue center light flashing, won't copy from any computer
So Sandra, it will make copies but does not print from any computer. Have you installed print drivers on the network? Can you ping the copier?, any resent changes to the network? Check the network connection at the copier, green light flashing/orange lights flashing? Can you print a doc. or a pdf., or email or web page try different programs? Check the network setting at the copier, go to admin setting default pw 12345678.
May 12, 2015 | Konica Minolta bizhub C250 All-In-One...
How do i clear error code C-D368 on bizhub C250 konica minolta
NVRAM= NON Volitatle Radom Access Memory. Need to have the firmware flashed and Mite also have the NVRAM replaced can not get on line secure Konica Minolta site. That Memory kkeps track copy count and certain machine info Serial Number etc.
Dec 04, 2014 | Konica Minolta bizhub C250 All-In-One...
When a print job is sent to my Konica Minolta Bizhub c352, it only flashes "data" light, but nothing prints.
Does this happen when you copy. Try different document and program pdf word web page etc. Static IP or DHPC? Recommend static IP for copier/printers
Feb 14, 2014 | Konica Minolta bizhub C250 All-In-One...
I HAVE Konica Minolta Konica Minolta C550 .WHEN I USED COPY OR PRINT EXITING PEAPER IS DIRTY OR HAVE BAR BLACK. PLEASE GUIDE ME
"Dirty" could be one of 3 things... Transfer belt, Imaging unit and fuser unit. Make 5 copies in jam the machine by opening a cover. remove pages and see where the "dirt" originates from.
Jan 08, 2014 | Konica Minolta bizhub Office Equipment &...
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is...
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Regards
M-PRESS.BIZ
Feb 09, 2011 | Konica Minolta bizhub C250 All-In-One...
I am trying to print a booklet with eight pages front and back from publisher 2007 on a Konica Minolta Bizhub C550 and when I print one copy it folds and staples fine. When I print two or more copies the...
first change driver, second print to hdd in printer, and then call this job from hdd and change copy amount. if this is not helping, then maybe the firmware is faulty, fw update is good idea
Oct 15, 2009 | Konica Minolta bizhub C250 All-In-One...
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
Print Fax Confirmation
The Bizhub C250 accepts the FK-502 Fax Expansion card like most other Konica Minolta Products so this data is relevant for many models. Below are the step to enable fax confirmation pages:
Press the fax button.
Press the Utility/Counter button.
Touch Administrator Setings.
Enter password (12345678) or (00000000) are the defaults.
Touch OK
Touch Report Settings.
Touch TX Report Settings.
Set TX Report to ON.
Close, OK, and/or Exit all the way out.
Oct 31, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
130 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
