Question about Bosch 24 in. SHU43 Built-in Dishwasher
The lower arm on my Bosch dishwasher is not working
I have recently installed a new PC board in the machine, but working through all possible program combinations on the set-up sheet cannot get this lower arm to spin while washing. I have checked that it spins freely and is not blocked with food. The ENR No. of the machine is: SGS56E02GB/35. There are two exits for wash water, one for each rotor, as far as I can see the lower arm supply is not blocked. Help!
5 Suggested Answers
SOURCE: bosch dishwasher arms dont spin, but turn freely
How do you know the arms are not moving? They are spun by the water jetting through them and they may be blocked. They just pull out and clip back in so run some mains water through them. Also if you put dishes or trays that are big they can obstruct the arms so give them a spin to see first.
Posted on Sep 05, 2008
  • 583 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
How to Check the Spray Arms Home > How To > Appliance > Dishwasher >Check 1x1.gif Caution: Please read our safety information before attempting any testing or repairs.
The pump/motor assembly pumps water up through the spray arms. The force of the water cause the arms to spin and spray the water and detergent mixture into the dish and glass racks. Some dishwashers have just one spray arm at the bottom in the tub, others have a second spray arm under or over the glass rack. Some dishwashers also have a spray tower that rises up out of the lower spray arm to concentrate an additional blast of water.
To access the bottom spray arm, remove the bottom dish rack. Reach in and spin the spray arms. They should spin freely. Lift up the spray arm from the end. There should some play in the arm allowing you to wobble it up and down. Inspect the seams of the arms for splits. If water sprays out of a seam, the dishes will not receive an adequate spray for proper cleansing and the force of the water directed at the door may cause leakage.
The lower spray arm may also have a spray tower. If it does, pull up the center part of it as far as it will extend and let it drop. It should lift and drop smoothly. You can also unscrew the tower by hand to inspect the interior for foreign objects that might clog it.
Remove the upper glass rack as necessary to access the upper spray arm. Repeat the steps above for the lower spray arm. The upper arm may not have as much wobble as the lower arm.
The water source for upper spray arm on some dishwashers may be through a tube which mates with the spray arm when the rack is pushed all the way back. Make sure that the rack is properly aligned with the water supply tube.
If necessary, the spray arm can be removed for cleaning or replacement. Unscrew the spray tower (if any) by hand and remove the bolt (if any) in the center of the spray arm. Otherwise lift and rock the spray arm until it comes off. Keep any washers in the same order as they are removed. To clean, soak it in warm water and rinse with a vigorous spray.
Posted on Mar 20, 2009
SOURCE: bosch wae24363 washing machine, coming up with f17 error code please help
I had this same message last week. It is to do with the water intake (i.e. the water coming in to the back of the machine). If you have checked that the hose isn't trapped or kinked, unscrewed it and checked the filters at each end for blockages (rinse out if necessary), and you still get the F17 message, it may be because your water pressure is too low, in which case you need to contact your landlord (if you rent) or thames water if the problem is external (especially if there are any works going on near your house). Hope this helps!
Posted on Jun 12, 2009
heatman101
  • 43501 Answers
SOURCE: bosch dishwasher no water coming from arms but not blocked
Here is a tip that I wrote about that....
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Apr 21, 2010
dmpitu
  • 3 Answers
SOURCE: Bosch Dishwasher ENR: SRV43MO3
Hello. The machine is 3 years old.
I cannot upload here the manual. To that direction(address) I it send?
Posted on Sep 03, 2010
I have a Bosch dishwasher Model No: SMU7056UC/14. The top rack does not seems to be cleaning good. I took out the filters under the lower wash arm and cleaned out the pump area. Any ideas would be very...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 14, 2011 | Bosch 24 in. SMU70 Built-in Dishwasher
Water in the dishwasher model Bosch srs 3012 at the end of the program remains a certain amount of water in the machine and the glassware is not washed enough
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 16, 2011 | Bosch 18 in. SRS43C02 Classixx Slim-Line...
Bosch dishwasher SHY 56A leaves scum/food particles on the dishes after full wash cycle
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Oct 30, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
The bottom spray arm of my bosch dishwasher will not spin. Nothing is blocking it, spins freely if you spin it by hand. We've tried resetting machine via control panel and also by circuit breaker, this...
heatman101
Oct 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Bosch dishwasher isn't cleaning very well. Leaves film on glasses
heatman101
Oct 25, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Can someone please help. No water is coming out of lower and upper spray arm. Spray arms are clean.
heatman101
Sep 26, 2010 | Bosch 24 in. SMU20 Built-in Dishwasher
Dishwasher bosch classixx not cleaning all dishes
heatman101
nmwr34
Jul 29, 2010 | Audiovox Bosch 718 World Cellular Phone
Not draining water and not cleaning all, pipes ok is machine just old bosch exxcel dishwasher
heatman101
e
Dec 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch dishwasher not cleaning dishes
heatman101
wyt42
Nov 25, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher leaks on occasion, and leaves scuz on the dishes. Any suggestions on what to do? Bosch quized me on the detergent I'm using and I've had a repair man out at least 4 times.
heatman101
Sep 24, 2009 | Bosch SHE45M06UC Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
