Question about Coleman Powermate Premium Plus 6250W Portable Generator
Engine problem the engine works but wont stay running like it isnt getting fuel
  • scott hyatt Oct 19, 2008
    Runs for a few minutes then sputters and stops. Carb. is clean, gas is fresh.
Now that I see your problem description it reminds me of my problem. Same thing. I think I got in touch with Tecumseh, the engine manufacturer, and ultimately found there was a problem in the fuel supply. It seems to me I poked a small hole in the carburetor or someplace where the fuel was to go thru. Making the hole bigger solved the problem. Tecumseh told me they had the problem with that engine. I wondered why they did not send out instructions to all buyers to poke the hole.
This was on a Powermate Ultra 2500, Model PMO422505.01
Posted on Oct 26, 2008
HI SCOTT,
I HAD SOMETHING LIKE THAT BUT MY PROBLEM WAS THE ENGINE WAS SURGING.
THE PROBLEM WAS SOMETHING WAS RESTRICTING THE FUEL FLOW.
TRY PULLING OFF YOUR CARB. BOWL AND WHERE THE BOLT SCREWS IN TO THE BOWL YOU WILL SEE A BRASS SCREW THAT SCREWS INTO IT USE A PAPER CLIP OR A TORCH TIP CLEANER OR WIRE TO PUT INTO THE HOLE. YOU WILL NEED TO REMOVE YOUR AIR CLEANER FROM THE CARB IN ORDER TOCLEEN THAT.
HOPE THAT HELPS YOU.................
PAUL
Posted on Oct 20, 2008
    Problem Solver:
  • 8 Answers
Clean and or kit carb check make sure carb is getting gas tank my not be venting
Posted on Oct 15, 2008
My gmc sierra SLT 350 isnt getting fuel to the engine.
if your carb is a tbi (throttle body injector) then the carb is clogged
Feb 25, 2014 | Cars & Trucks
99 suburban starts but doesnt stay running
Our F-150 had a similar problem. It was a cam phaser, then timing sensors, I believe, had to be changed as well.
Aug 21, 2012 | 1999 Chevrolet Suburban
If my car wont stay running what could be the cause?
could be numerous things if you dont supply a description of what it does we cant help. but sounds like maybe the idle isnt right or the alternator might not be working properly, or your having a problem getting fuel, try the fuel filter, check alternator, check all ground wires.
Feb 20, 2012 | 1994 Oldsmobile Cutlass Ciera
Parked the truck and now it wont start,,new fuel pump/filter.will run for a min if sprayed with starting fluid but wont stay running yes has gas in it 1995 chevy s10 4 cyl
check change the fuel filter and check the vacumn to the fuel pressure regulator also check the fuel lines to make sure one isnt collapsed as well
Jan 21, 2010 | 1995 Chevrolet S-10 CA Edition
No efi
put the key in on position open the air filter and press the tounge for the MAF sensor and listen if the pump comes on. let me know what happen
Apr 25, 2009 | 1990 Toyota 4Runner
Car wont start and acts like it aint getting no gas
change fuel filter.check fuel pressure.
Apr 06, 2009 | 1991 Dodge Dynasty
Fuel
the fuel filter sounds like the problem, are you sure its carborated not fuel injucted because fuel injuction has a regulater for the fuel if it is stuck open you would pump gas to the fuel rail and back to the fuel tank
Dec 23, 2008 | 2000 Oldsmobile Bravada
96 sunfire
fuses. please email me at meanness628@aim.com with any other info or questions
Jun 17, 2008 | 1996 Pontiac Sunfire
Coleman Powermate Premium Plus 6250W Portable Generator Logo
360 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
